12 secs.?
Old Oct 19, 2001 | 12:17 AM
Tung-Twista's Avatar
Tung-Twista
Question 12 secs.?
I'm thinking of buying a '93 Gs300. I was wondering: what kind of mods would i have to pull to get this car into the low-to-mid 12 second range? Also, how much would all this cost? The cheaper the better. Any comments appreciated, and thanks.....
Old Oct 19, 2001 | 12:24 AM
GlobeCLK's Avatar
GlobeCLK
low 12s, you'll definitely need some kind of forced induction. Luckily, for 93~97 GS300s the bolt-on turbo kit is relatively easy to get and install. You can Private Message "JZS147" for more info. I think his turboed GS300 can do 11s.
Check out suprastore.com. They have a kit for that GS.
Old Oct 19, 2001 | 09:37 AM
v300's Avatar
v300
I wish separating the head from the block to change head gasket and reassembling/torquing down the head to the block were as easy. To get such a heavy car to dip into the 11's the car would have to suck enough air and burn enough fuel to lay down 450hp to the ground, have a two-way LSD (3.76 gearing), decent wide rear tires (at least 265 wide) and finally a 3200RPM stall torque converter. You'll be on your way to 11's.
Old Oct 20, 2001 | 12:05 AM
Tung-Twista
Thanks guys....I really appreciate your help, and I'll take it into heavy consideration when I make my decision
Old Oct 20, 2001 | 12:45 AM
GlobeCLK's Avatar
GlobeCLK
Maybe I should say "easy to get" and not "easy to install"
I mean easy because there isn't the problem with the VVTi and ECUs like the 98+ 160 series. Still alot of work, but at least no thinking-your-butt-off-for-getting-ECU-to-work thing.
Old Oct 20, 2001 | 05:56 AM
SC300TURBO's Avatar
SC300TURBO
toyomoto can build you a kit for what ever hp you want...with 440 rwhp i went 11.90s @115....the f-max kit isnt gonna make that kind of power and is very poor quality.....the gs300 up to 95 are easy to work with due to OBD1 computers.....call toyomoto 305-599-3050..Jeff
Supraristo
Performance
Aug 2, 2004 01:08 AM
j0hnyboi
Oct 14, 2003 06:54 PM
SC430 ME
Performance
Jul 10, 2003 08:17 AM
markman130
Performance
68
Sep 11, 2002 01:10 PM
