Changing AT Fluid
Old Oct 8, 2006 | 03:21 PM
landarc's Avatar
landarc
Default Changing AT Fluid
Hi. I am about to change my AT Fluid based on the DIY website: http://lexusmodz.netfirms.com. He recommends using a new crush washer (P/N 35178-30010 or P/N 35178-50010). Should I get a new one or can I reuse the same one? Any recommendations? Thanks.
Old Oct 8, 2006 | 06:27 PM
GSteg's Avatar
GSteg
I was able to reuse mine, but I limit the washer to only 2 intervals before I change out for a new one.
Old Oct 11, 2006 | 07:46 AM
PRSUIT460's Avatar
PRSUIT460
You can re-use the old one but I would use a new one since they are cheap and it will prevent a leak.
Old Oct 11, 2006 | 08:37 AM
bmgs400's Avatar
bmgs400
I did my own tranny fluid change several times (around 10 times) and never had replaced the washer. A snug fit is all you need so then the washer can be reused with out risk of leaks.
Old Oct 11, 2006 | 12:13 PM
chuckb's Avatar
chuckb
re used mine no prob.
Old Oct 11, 2006 | 06:40 PM
landarc's Avatar
landarc
Thanks for all the advice. I am going to buy a new one on Saturday and change it this weekend. Hope it stays warm. It is going to 4 degrees celcius. Brrrrrr!
Max707
LX - 3rd Gen (2008-2021)
Apr 12, 2015 10:01 AM
DMPesso
Performance
16
Dec 10, 2010 11:55 AM
runningox
Apr 5, 2009 08:10 AM
cdvmagic
Maintenance
Jan 31, 2007 11:44 AM
