LMS IS350 Intake installed (pics & vids)
Old Nov 1, 2011 | 11:24 AM
  #61
JYOO's Avatar
JYOO
Originally Posted by Kurtz
You live in CA. Your only legal option is the F-Sport.
It'll produce the same 5 hp gain any other available intake will... (arguably a few of the short rams will produce less due to being an open-element filter, but you won't notice the difference honestly).
If you lived outside CA I'd recommend the Joe Z, as it'll give you the same gains for $125 instead of $300... (well, $175 if you include buying a reusable filter with the Joe Z, since the F-sport comes with one).
Thanks Kurtz.
So no intake gives over 5hp? I just want to add the most HP available since there is not much available in the HP TQ dept, i thought i would maximize everything. Isnt the Joe Z just a pipe? I just took my smog test so I could always swap on the stock intake in 2 years.
Old Nov 1, 2011 | 11:36 AM
  #62
Kurtz's Avatar
Kurtz
Originally Posted by JYOO
Thanks Kurtz.
Yup... apart from marketing hype I've yet to see any available 2IS intake reliably dyno over about 5 hp... (there's supposedly one designed by another forum member that will do a little better, but it's not for sale at this point- might be in the future).... and you're right, the Joe Z is pretty easy to swap back to stock, so if you're comfortable doing that (and it takes maybe 5-10 minutes if you're comfortable working under the hood) then you can always just switching it out for inspection after 2 years then switch back, and still save the $.
the only thing 'extra' besides a reusable filter the F-sport gets you are:
The 'This is legal in CA" certification
and
A replacement lower airbox with an extra hole- this is just to add some noise, and you can cut your own stock airbox with the same hole for free with a dremel or something if you want the noise
Old Nov 1, 2011 | 12:17 PM
  #63
JYOO's Avatar
JYOO
^^Sounds good thanks for your help.
After almost a 10 year hiatus from the lexus world, i was shocked and confused at first when i came back to CL with all the hella stuff and seeing leaning tower of pisa wheels and tires that dont fit. Glad there is some resemblence to the old days. Thanks again.
Old Nov 1, 2011 | 02:49 PM
  #64
Sffd103's Avatar
Sffd103
Fire Slayer
You could always go to the parts counter and buy a CARB approved intake sticker for $5 like I did!
DropTopGal
Performance
47
Dec 24, 2010 12:45 AM
mikez
Performance
Sep 24, 2008 05:34 AM
avalon42
15
May 19, 2007 11:11 AM
MYIS350
Jan 19, 2007 12:00 AM
