Gs470
Old Feb 5, 2006 | 12:24 PM
Lextreme's Avatar
Lextreme
Default Gs470
I have been thinking about this. I plan to get a GS400 or GS430 in the next 4-6 months. I was wondering if i get a GS400 and swap the bottom end to the Tundra 4.7 block with custom pistons and forged H Beam Rods. I want to run it in NA form and bring the compression ratio from 10.5: to 11:1. With good exhaust flow and if cams available in the future, this combo should bring me up to about 350 to 375 bhp. What do u guys think of this?
Old Feb 5, 2006 | 12:44 PM
fireballs gs400's Avatar
fireballs gs400
Default I think Its a great idea
Could a possible engine rebuild with stronger parts w/o the tundra bottom end do about the same thing? I think someone makes custom crank kits for the 4.0 or 4.3...but the 4.3 has lesser internals.
Old Feb 5, 2006 | 12:50 PM
chuckb's Avatar
chuckb
I don't know if the block and heads have the same dimensions, but it sure sounds like a cool idea to me.
I've also thought of the possibility of buying a high mile GS and put a Ford 4.6 or a Chevy V8 (like they do with FD RX7s)motor/trans/rear end in. Then you could make big hp cheap. I think it'd be a cool sleeper/drag car.
Old Feb 5, 2006 | 02:04 PM
BLAZE's Avatar
BLAZE
That would be very cool. Chuck b If u could somehow put a built-up ford 302 or 351 (possibly a stroked out version) with a supercharger and a tremec 6-spd trans with the supra 376 rear................OMG what a beast and for 1/2 the cost. But i i would still rather have oem- toyota lexus go fast parts.
Old Feb 5, 2006 | 02:17 PM
Lextreme's Avatar
Lextreme
It might be cheaper to do a 4.7 liter 2uzfe shorblock then swapping a Ford or Chevy crate motor. All the Toyota V8 shortblocks are the same. So its a bolt on. However, i think the cost would be greater if swap to domestic engines. The only problem would be an extra 82 lbs. However, if i can change the stock hood to CF hood that will save about 30 lbs.
Old Feb 5, 2006 | 03:29 PM
GSteg's Avatar
GSteg
No better time to diet than right now!
Old Feb 6, 2006 | 02:17 PM
chuckb's Avatar
chuckb
here's a RX -LS swap. you get the idea.
Old Feb 6, 2006 | 03:01 PM
Richie's Avatar
Richie
Go for it
I for one would like to see how this turns out
Madoli726
Performance
Jan 17, 2011 08:10 PM
McKrevice
Oct 18, 2010 06:19 AM
Lextreme
Jul 13, 2009 06:36 PM
RRocket
Oct 9, 2004 06:11 AM
