New short block
Old Jan 26, 2006 | 09:37 PM
jp430's Avatar
jp430
Default New short block
First, big shot out to lextreme for his help in this project. My main goal was to safley up the HP for my 2001 GS430. I lowered the compression to 9:1 with Ross forged pistons, went with the 1uz rods (much stronger), all new gaskets, and ARP studs. I plan to be pushing 10-12 lbs. of boost. I want to stay with stock ecu/injectors. I do not know right now what the max amount of boost I can go with the stock injectors. I am currently in the process of just braking the motor in. Here are some pictures I wanted to share with you guys
Ross pistons
1uz vs 3uz
Short block
Old Jan 26, 2006 | 10:43 PM
SuprRunner's Avatar
SuprRunner
Now that is a PURDY sight.
Man, those small rods...I can't believe those just don't snap at the slightest things. Those things aren't even straight. I is like a toothpick with a big and small end. Yikes.
Old Jan 27, 2006 | 05:51 PM
RRocket's Avatar
RRocket
Could you have stroked it to 4.7 L????
Old Jan 27, 2006 | 11:19 PM
LexT's Avatar
LexT
Ross pistons
1uz vs 3uz
Short block
How many cc's are the stock injectors? What tuning tool are you using, how much boost are you running? Are the 400/430 injectors the same? thanks
Old Jan 28, 2006 | 07:07 AM
LMSguy's Avatar
LMSguy
No way your going to be able to run 10-12LBS with stock injectors.
Old Jan 28, 2006 | 11:43 AM
Dx3's Avatar
Dx3
I am running about 11lbs of boost with 440 injectors. With 310's I was maxxing out my injectors at 8lbs.
Jonny
Old Jan 28, 2006 | 06:12 PM
BLAZE's Avatar
BLAZE
Wow very nice. How much does one of those shortblocks cost? Are they fully assembled?
Old Jan 29, 2006 | 12:20 AM
LexT's Avatar
LexT
Jonny
So, the stock GS 400/30 injectors are 310's ?
Old Jan 29, 2006 | 04:07 PM
jp430's Avatar
jp430
Jonny
Are you using the stock ecu for those 440's? How does it run? How many miles have you been using the 440's?
Old Jan 29, 2006 | 04:37 PM
jp430's Avatar
jp430
Good question!!! Do the 400 and 430 use the same size injectors....stock. If the 430 uses bigger injectors, maybe I can get a few more pounds...10lbs.......????
Old Jan 29, 2006 | 04:40 PM
trbopooh's Avatar
trbopooh
Stock injectors are 270cc
Old Jan 29, 2006 | 05:36 PM
Lextreme's Avatar
Lextreme
According to Lexus OEM Repair Manual, the 2002 GS430 is about 240 to 292 cc/min
Old Jan 29, 2006 | 09:10 PM
jp430's Avatar
jp430
So....they are smaller?
Old Jan 30, 2006 | 07:36 AM
Lextreme's Avatar
Lextreme
John,
You can look into some of mild injectors upgrade without killing your idle:
MKIII Supra 7MGE (early model) 295 cc/min (Yellow) Mod: Change plug or mod the injector grooves
or
MKIII Supra 7MGE (later model) 315 cc/min (Lime Green) Mod: Change plug or mod the injector grooves.
I think the 315 will support 9.5 to 10 psi.
Old Feb 9, 2006 | 10:34 AM
GILLEXUS's Avatar
GILLEXUS
JP430
So you replaced the entire engine block,pistons and rods? Couldn't you have just replaced the rods and pistons the weak link or does the entire lower end needs to be strenghtened??
Are you sticking w/the I-manage for your fuel management?
This should be a beast w/ the rebuild.
