Cold Air Intake
Old Jan 23, 2006 | 09:02 PM
the lndr's Avatar
the lndr
Default Cold Air Intake
Last week I drove down to Monrovia to Luxury Motorworks. Steve installed the CIA for the first time on my is 250. It got about 7 hp on the dyno which was ok but did really good on the extra torque. It sounds better know and is getting a little better gas millage. Pictures to come soon. I really enjoyed my time with them.
Old Jan 23, 2006 | 09:26 PM
Yuri's Avatar
Yuri
what type of filter do they have? paper or foam?
Old Jan 24, 2006 | 05:44 AM
caymandive's Avatar
caymandive
11 Second Club
I have an intake coming in soon and I believe they are K&N filters.
Old Jan 24, 2006 | 05:45 AM
mcfly's Avatar
mcfly
Can you scan the dyno sheets from the before and after pulls? I'd really like to see...
Old Jan 24, 2006 | 06:26 AM
Tony1's Avatar
Tony1
7 hp from just an inatke is better than Ok!, what kind of sound does the
intake make???
Old Jan 24, 2006 | 06:31 AM
SilverBolt's Avatar
SilverBolt
Was the ECU cleared before the dyno run?
Old Jan 24, 2006 | 07:47 AM
w0ggy's Avatar
w0ggy
I've heard that a CIA will mess with the fuel/air ratio and can be bad for the car during long drives. I dont really know too much about car upgrades, can anyone help me out here? Is this true? If so, can anything be done to prevent it?
Old Jan 24, 2006 | 09:22 AM
onihc's Avatar
onihc
I heart Honda
Thanks for the info, as I drive the 250 as well. Is this intake a true cold air intake by sucking air from the wheel well, or outside the engine compartment? Or is this sucking hot air from the engine compartment?
thanks
Old Jan 24, 2006 | 02:29 PM
the lndr's Avatar
the lndr
I called Luxury MotorWorks and ask for Pictures to post. Steve Larkin is Lexus Certified Master Technician who work on it. He has all the specs on the dyno for my car . He can be reached at 626 358 2165.
Old Jan 24, 2006 | 02:40 PM
the lndr's Avatar
the lndr
Sorry on my last post I forgot to say that its sounds mean.
Old Jan 24, 2006 | 03:01 PM
shaolin's Avatar
shaolin
how can intake save for gas?? if you get more airflow with more fuel mix to gain more hp.
please correct me if i'm wrong
thanks
Old Jan 24, 2006 | 03:49 PM
Bichon's Avatar
Bichon
thanks
Same way that replacing a dirty air filter with a clean one increases mileage: less of the engine's power is used to pump air through the motor, leaving more to spin the wheels. So for the same amount of acceleration, you burn less gas. Unfortunately, in the real world, the savings are usually pretty negligible.
Old Jan 24, 2006 | 06:31 PM
blkIS350's Avatar
blkIS350
Are they making an intake for the 350 or is anyone currently making one yet?
Old Jan 24, 2006 | 07:59 PM
NINEZeRO's Avatar
NINEZeRO
Bichon do you know if a CAI will void any of the warranty? How bout a exhaust other than the factory HKS? Thanks
Old Jan 24, 2006 | 09:13 PM
rominl's Avatar
rominl
exclusive matchup
make it was. he is no longer a lexus master tech once he left lexus, i believe
and yes, i wonder if the ecu was reset between the two dyno runs? that would be important
and shaolin, intake technically can help on gas mileage. yes it's more air, but no it's not more gas. the injectors still put in the same amount of gas i believe?
