Header Install HELP
Old Nov 29, 2005 | 01:29 AM
  #31
FutureGS400's Avatar
FutureGS400
Originally Posted by trbopooh
Hey Mike,
It's actually the same problem that I had with mine. Dealt with it the same way.
OK, I thought I understood the issue you had with yours, but now I see the problem...like they say -"a picture is worth a 1,000 words!"
You guys have sure helped the rest of us who haven't got around to the install yet! THANKS!!
Old Nov 29, 2005 | 04:09 AM
  #32
GILLEXUS's Avatar
GILLEXUS
BA GS400,
Did you use reuse the stock header to cat gasket or do you think a new one should be bought? Does the gasket fit inside the recessed part of the header or does the ridge from the cat fit inside the recessed part of the header?
Old Nov 29, 2005 | 05:30 AM
  #33
BA_GS400's Avatar
BA_GS400
The Ridge that you pointed out in that diagram is what now fits just inside the flange.
I used my old convertor gaskets because I had read from someone else that this was going to be possible. Since it is a copper gasket, it *looked* ok and I went ahead and used them. The gasket at each end looked identical, although I didn't measure them.
If they are only a few bucks each, I would have bought 4 of them for this project. I just wasn't thinking that far ahead. I did buy new manifold to head gaskets though.
On the convertor and also on the original manifold, there is a slight indented ring on the flange that the gasket seals against. The header doesn't have this but I don't think it's a big deal since the convertor does have it, and we've got that ridge to go up in the header collector pipe.
Old Nov 29, 2005 | 08:13 AM
  #34
GILLEXUS's Avatar
GILLEXUS
I found your othr header post and it makes more sense to me now. thanks.
Checking with Carson Toyota the header/manifold gasket is $21 and the upper and lower cat. gaskets are $10 each. Had a chance to drive it yet?? How does it drive?
Old Nov 29, 2005 | 08:15 AM
  #35
JBrady's Avatar
JBrady
MUCH better, I now clearly understand your concern and your concern is completely correct and your solution is the correct solution. I have contacted S&S and they will make the required changes to new production. For all of us that have already received our parts I recommend BA's solution. Thanks
Old Nov 29, 2005 | 10:33 AM
  #36
BA_GS400's Avatar
BA_GS400
Thank you John!
I picture truly is worth a thousand words, eh? I've got almost a dozen-thousand words up there!!!
alee350
Mar 14, 2024 09:00 PM
TwixTM
RC F (2015-present)
Jun 28, 2018 05:55 PM
VDODSON
IS F (2008-2014)
Aug 31, 2016 07:05 PM
RichFlair
IS F (2008-2014)
May 15, 2015 02:33 PM
sam430
Feb 1, 2009 11:03 PM
