Header Install HELP
Old Nov 28, 2005 | 03:28 PM
BA_GS400's Avatar
BA_GS400
Default Stock Manifold Flange and pipe
Stock Manifold Flange and pipe (repost)
BA_GS400's Avatar
BA_GS400
Default Stock manifold-catalytic no gasket
Attached Thumbnails Header Install HELP-3-gs400-stock-manifold-catalytic-no-gasket.jpg
Old Nov 28, 2005 | 03:29 PM
BA_GS400's Avatar
BA_GS400
Default Pass. Header Flange
Pass. Header Flange
Old Nov 28, 2005 | 03:32 PM
BA_GS400's Avatar
BA_GS400
Default 5 GS400 Driver Header Flange2
Old Nov 28, 2005 | 03:35 PM
BA_GS400's Avatar
BA_GS400
Default Header to catalytic
Header to catalytic
Old Nov 28, 2005 | 03:36 PM
BA_GS400's Avatar
BA_GS400
Default Header to catalytic 2
Old Nov 28, 2005 | 03:37 PM
BA_GS400's Avatar
BA_GS400
Default Modified Header
Modified Header
Old Nov 28, 2005 | 03:38 PM
BA_GS400's Avatar
BA_GS400
Default Modified Header 2
Modified Header 2
Old Nov 28, 2005 | 03:39 PM
BA_GS400's Avatar
BA_GS400
Default Modified Header to Catalytic convertor
Attached Thumbnails Header Install HELP-11-gs400-modified-header-to-catalytic-no-gasket.jpg
Old Nov 28, 2005 | 03:41 PM
BA_GS400's Avatar
BA_GS400
Default modified header and catalytic
Attached Thumbnails Header Install HELP-12-gs400-modified-header-and-catalytic.jpg
Old Nov 28, 2005 | 03:42 PM
BA_GS400's Avatar
BA_GS400
Default modified header and catalytic 2
Attached Thumbnails Header Install HELP-13-gs400-header-to-catalytic-w-gasket.jpg
Old Nov 28, 2005 | 03:48 PM
BA_GS400's Avatar
BA_GS400
Some of you might be thinking "wow, he went the hard route" and you are probably right.
I could have done any of the things JB mentioned earlier but this is the route I wanted to take. I think it's more like the factory design, I get to use the factory copper gasket instead of some aftermarket gasket, and I think I'm *more* assured of a leak-free fitment. For me, it was worth the time.
The absolutely quickest fix would have been to do what I think TRBOPOOH (or someone) did and grind down the little tube coming out of the catalytic convertor.
Old Nov 28, 2005 | 04:13 PM
trbopooh's Avatar
trbopooh
Glad you got everything worked out. You shouldn't have any problems if there aren't any exhaust leaks.
Old Nov 28, 2005 | 07:53 PM
FutureGS400's Avatar
FutureGS400
Mike, this isn't the same problem you had with yours...or is it? I was thinking you had some kind of metal ring or gasket you had to grind down?
BA-thanks for the pics and description! Very helpful...
Old Nov 28, 2005 | 08:21 PM
trbopooh's Avatar
trbopooh
Hey Mike,
It's actually the same problem that I had with mine. Dealt with it the same way.
