View Poll Results: which plug do u recommend?
ngk IFR6A11
21.88%
denso SK20R11
18.75%
torquemasters
16
50.00%
other
9.38%
Voters: 32. You may not vote on this poll
yet another spark plug poll
Old Sep 21, 2005 | 01:09 PM
Benjamin T's Avatar
Benjamin T
Default yet another spark plug poll
which spark plug is best? and why did lexus go from ngk on early 2nd gen gs400's and ended up with denso in the later 2nd gen models?
Old Sep 21, 2005 | 01:10 PM
Benjamin T's Avatar
Benjamin T
oh sorry we're talking about the GS400 here.
Old Sep 21, 2005 | 01:42 PM
Benjamin T's Avatar
Benjamin T
i was on http://www.ngk.com and it lists the gs400 application as something else:
http://ngk.com/results_app.asp?AAIA=1356072
and that the IFR6A11 no longer exists?
Old Sep 26, 2005 | 02:28 PM
Benjamin T's Avatar
Benjamin T
Default what spark plug do u recommend PART II
this is in reference to this earlier poll i had posted up:
https://www.clublexus.com/forums/pol...ts&pollid=1463
it seems like everyone is using torquemasters.
i know that when going from old plugs to new ones it always feels stronger... but has ne1 here gone from new ngk or denso plugs to torquemasters? i thought i read a post somewhere of someone having done this but i can't find it... must be my imagination.
Old Sep 26, 2005 | 02:47 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Merged your threads, no need to start a second one .
I put Denso Irridiumin AFTER my TM's and wanted to change back to TMs. Did it as a matter of convenience (couldn't get my hands on a set of TMs) but had a perceived (butt-dyno) and real (dyno) reduction in RWHP after removal of the TMs.
Mean Gene did his original dyno test on pretty new Denos vs TMs if I recall correctly.
Old Sep 26, 2005 | 03:01 PM
Benjamin T's Avatar
Benjamin T
someone just pm'd me saying that i missed a GB for TM's? does ne1 know if there will there be another one?
Old Oct 12, 2005 | 01:23 PM
plugmaster's Avatar
plugmaster
the ifr6a-11 isn't available to the aftermarket yet
Old Oct 14, 2005 | 08:25 AM
Benjamin T's Avatar
Benjamin T
really? that's what my local parts place offered me off the shelf (LORDCO)...
i'm a noob at this. all i know is what others like this shop tells me... and they don't carry torquemasters or denso. they did try to sell me autolites though.... yick.
Old Oct 15, 2005 | 08:12 AM
natnut's Avatar
natnut
Default Contact SUPRATRD ( Carson Toyota rep)
I just received and installed a set of 6 TM plugs from Carson Toyota. My GS300 is definitely smoother and more responsive and definitely feels quicker--not just me but my family also noticed the difference.
PM Steve( SUPRATRD) about the TM pricing, I think you'll be pleasantly surprised . You'll have to order via l-tunedparts.com website.
I heartily recommend these spark plugs--there is no downside (however I've had them on only about 1000 miles)
Old Oct 15, 2005 | 10:51 AM
blacksc400's Avatar
blacksc400
Car Chat Moderator
I will go TM when I need to change my Sparkplugs.
Old Oct 20, 2005 | 02:26 PM
aristo400's Avatar
aristo400
I just replaced my TM plugs with about 50k miles on them with the stock plugs with 50k miles. The idle on the car was getting rough with the TM plugs. To my surprise the idle (in D) is now smoother. Gas mileage is the same so far and I'm not sure on the overall power output. I'm not sure if the TM plugs are getting worn out. There is no gap spec. for the TM plugs. If your idle is a little rough with the TM plugs you might want to try swapping them out.
Also I didn't reset the ECU, so the ECU should still be retaining the same running parameters.
-Jeff
P.S. If anyone wants my old plugs for $20 including shipping, PM me.
Old Oct 20, 2005 | 04:10 PM
joshoowa's Avatar
joshoowa
i have TM plugs and i do notice a slight pickup... i notice it more when i get up on the gas while on the freeway.
for the gs300s when guys do spark plug change make sure u clean out the TB it improves that harsh sluggish around 2k-2.5k rpms
reset the ecu and ur engine should be purring
Old Dec 24, 2005 | 02:54 AM
MeanGene55's Avatar
MeanGene55
Talking It's Me!!
Dave - I'm back!! I haven't dropped in for a LONG time & thought I'd check up on ya'll. Here's the link to my TM comparison experiment: https://www.clublexus.com/forums/performance/50745-tm-dyno-results-awesome.html
As for my G35, I'm building an AEBS motor w/Darton sleeves ( it'll be a 3.8 liter ) & going w/ a "T" trimmed Vortech ( for now ). The heads will have a mild port/polish & 1mm oversized Ferrea valvetrain & Jim Wolfe Technology cams. Using Arias HD pistons, Pauter rods & NISMO crank, I expect to make 550-600 rwhp on the S/C plus I've upgraded the fuel system to handle another 150 hp shot of nitrous! The block's @ AEBS now & should be back to me in January for the rest of the install. Of course the stereo's done ( w/ Focal Utopias & Eclipse sub & run off of older RF Power amps ). Well, not quite done as I just picked up a RF Symmetry which means I need to rewire the whole thing!
I'll post pics as things develop & it's good to drop in on my old friends!
Gene
ychachad
38
Jan 11, 2017 08:07 AM
pitmanr200
Mar 12, 2008 10:29 AM
RAristo
Performance
Apr 24, 2005 04:03 PM
johnee78
Maintenance
Jul 8, 2004 11:03 AM
