Where to get Front Mount intercoolers
Old Aug 31, 2005 | 10:17 AM
  #31
Lextreme's Avatar
Lextreme
You might consider top to bottom type of IC. Lot more effecient. Somthing like this Bar and Plate IC
Old Aug 31, 2005 | 07:12 PM
  #32
HI98GS's Avatar
HI98GS
Originally Posted by TLW
very similar to mikal EDIT : this is Mikal design
thanks man .....this is the one im going to go with
im hoping this is going to work
I am sorry, but i don't see how this new piping will be any different than your existing setup. unless the piping in green is behind the radiator. The intercooler will still have the same effectiveness as your original setup. Actually it may be worse since you will probably get less cool air going through to you radiator even if you get a larger intercooler.
You will likely need to have the air FROM the SC go into the pipe in green and enter the manifold from the pipe in blue. It would defeat the purpose of you cooling the air if you send air the way you have it drawn because the air will start to get heated from the heat from the radiator. My humble opinion
check your pm for my number
510to808
Sep 13, 2013 09:49 PM
pct91
Sep 8, 2013 01:17 PM
sunjinee87
Dec 20, 2004 12:11 PM
