Went to the track last night
Old Aug 24, 2005 | 06:31 AM
Burton's Avatar
Burton
Default Went to the track last night
60'...................2.210
330.................5.939
1/8..................8.773
MPH...............84.90
1000............11.184
1/4...............13.202
MPH............112.86
When I learn how to drive I will get her in the 12's
Ben
Old Aug 24, 2005 | 06:50 AM
BUSTN's Avatar
BUSTN
With your mph, you def. should be in the mid to lower 12's.Your not hooking with a 60' like that.Maybe some drag radials or even et streets will help.
Old Aug 24, 2005 | 07:15 AM
Nice numbers Burton - what's your car setup!?
Old Aug 24, 2005 | 07:23 AM
bluelex's Avatar
bluelex
wow, your has just the swap and that all right?
Old Aug 24, 2005 | 11:51 AM
chuckb's Avatar
chuckb
that's what I thought Burton bought an Aristo TT front clip, right? those numbers are high HP to be 112 mph.
where did the extra hp come from?
Old Aug 24, 2005 | 02:59 PM
Burton's Avatar
Burton
I have Nitto 555R's the car just bogs out of the hole. I don't know why. I can't get it to stall up high enough without braking the tires loose.
I have full 3" exhaust, no cats, boost controler and an AFC II. With 110 race gas.
That is it. I love this motor.
Ben
Old Aug 24, 2005 | 06:30 PM
Ben
OK, how about what car do you have? GS300, 400, 430? Is it an Aristo TT as someone said? What other mods?
I had Nittos - I thought they sucked. Lousy traction, noisy, not smooth.
Old Aug 24, 2005 | 07:18 PM
Burton's Avatar
Burton
The car is a GS300 with an Aristo 2JZ-GTE VVTI in it. Stock turbos and sidemount.
There is a post somewhere with pictures.
Ben
Old Aug 24, 2005 | 07:37 PM
CinFulxgs's Avatar
CinFulxgs
If you don't mind me asking... how much did the swap run you?
Old Aug 24, 2005 | 09:25 PM
Burton's Avatar
Burton
here is the whole deal
https://www.clublexus.com/forums/sho...ghlight=burton
Old Aug 24, 2005 | 09:38 PM
Indio's Avatar
Indio
Ben I assume you went to Gateway? How much is the race fuel per gallon now? Not sure what your tire pressures are but try lowering the rear to low 20's, the extra sidewall flex should help with your launch, also as Fall comes comes in the lower temps and humidity (turbos hate humid air) will get you down into the 12's no problem.
Old Aug 25, 2005 | 07:29 AM
Burton's Avatar
Burton
110 is $6 a gallon
112 is $7 a gallon
The tire pressure was at 22psi. The tires arn't spinning it is like the car pulles all the timing out in 1st gear and dosn't come alive unitll second.
Ben
Old Aug 25, 2005 | 01:42 PM
Richie's Avatar
Richie
Pretty good numbers for a heavy car like the GS.
Old Aug 25, 2005 | 02:12 PM
Indio's Avatar
Indio
Ben what rpm are you launching at?
Old Aug 25, 2005 | 02:38 PM
Burton's Avatar
Burton
That is a good question. I am still having a tach problem I hope to have it figured out in a week or so.
I basicly mash the brakes as hard as I can and try to get it as close to braking the tires loose as posable without actualy doing it.
Ben
