Squeal At Cold Start
I HAVE A 98 GS400 AND LIVE IN NYC. WE ARE HAVING SOME VERY COLD TEMPS. TODAY IS 13 DEGREES. I STARTED MY CAR AND IT SQUEALLS LIKE A PIG. I TRIED BELT DRESSING AND IT DOESN'T DO sH*&^ T. I OPENED THE HOOD AND NOTICED THE SQUEALING NOISE COMING FROM THE PULLEY ABOVE THE RADIATOR HOSE (TOP PULLEY). THE DEALER EVEN REPACED THE BELT FOR ME A WHILE BACK AND PUT BELT DRESSING ON IT. ANY SOLUTIONS GUYS? WHAT CAN I DO TO SOLVE THE PROBLEM?
I'd hate to see someone give you a mundane answer like "just wait till the belt warms up" you shouldnt have to if the thing is new.
btw....did you spray the belt dressing on the BELT? or did you spray it on the contact points of the belts where they meet the pulleys?
im going to say no
Wd-40 has some of the amazing uses ....
its a lubricant but at the same time it can dry out things that get wet
one example i can think of right now is a distrubitor cap if got wet spray a little wd40 and your good to go
ill think of more later
but like i said i cant be sure
but its worth a shot
Lubricates manifold heat control valve
• Helps clean sidewalls on tires
• Removes tar from chassis
• Removes decals from windows and bumper
• Removes insects from front grill
• Cleans motorcycle chains
• Removes grease from clothing
• Removes adhesive tape without damaging factory paint
• Helps hone cylinder walls
• Protects corrosion-sensitive areas of car
• Prevents corrosion of spark plug cables
• Shines motorcycle finish
• Removes sludge from outside engine block
• Removes asphalt from trucks
• Cleans grime from engines
• Cleans and protects chrome on cars
• Helps remove brake dust from wheels
• Restores shine on classic cars
• Keeps hitch locks rust-free
• Cleans road oil from rocker panels
• Cleans and protects aluminum rims
• Shines car tires
• Cleans marks from rubber surfaces
• Cleans rusty bolts
• Keeps brake levers clean on motorcycles
• Removes greasy fingerprints from car interior
• Lubricates key holes
• Removes silly putty stuck on car seats
• Lubricates trunk latch
• Spray on snow chains to keep from rusting
• Removes roof mastics from tools
• Removes tree sap
• Keeps car battery terminals clean
• Cleans lock nuts around gate valves
• Unsticks car door during cold weather
• Lubricates car antenna
• Helps remove stubborn rust from tow ball
• Cleans and protects power antennas
• Cleans white wall tires
• Cleans buildup from wood trim
• Removes asphalt from tools
• Lubricates tire air *****
• Removes glue from leather
• Lubricates valves on fire trucks
• Cleans pigeon droppings from cars
• Lubricates rusted fasteners
• Protects most vinyl surfaces
• Lubricates license plate bolts and screws
• Tones down shine of polyurethane
• Lubricates oil filter gasket
• Keeps tire jack working smoothly
• Cleans reusable air filter elements
• Maintains dashboard
• Removes melted crayon from upholstery
• Cleans and protects rubber boots of drive axles on front-wheel drive vehicles
• Keeps rubber door weather gaskets soft and pliable
• Cleans PVC valves
• Keeps windshield wipers rust-free
• Coat truck bed before installing bed liner to make removal easier
• Removes rust from side view mirror
• Cleans grease from rubber hoses
• Shines and protects bed liner
• Cleans gunk from travel trailer siding
• Lubricates sunroof crank
• Cleans and protects rear view mirror ***** and sockets
• Lubricates child safety seat buckles
• Lubricates socket wrench
• Cleans battery chargers
• Lubricates door latch to gas cap
• Displaces moisture from spark plug wires
• Cleans and protects engine compartment
• Keeps glove box lock working smoothly
• Helps clean messes from crevices and holes in clunker van
• Cleans rust from car hood latch
• Removes tar and grease from upholstery
• Keeps trailer hitch receiver and insert looking new
• Keeps RV slides rust free
• Keeps rubber particles from sticking to drag race car quarterpanels
• Buff out scuff marks on bumpers
• Lubricates emergency brake cable
• Quiets squeaky leaf springs
• Helps remove skid marks from cement
• Lubricates go-cart gears
• Gets gunk off steering wheel
• Removes road debris from license plate
• Removes cell phone antenna glue from glass
• Eases assembly of vinyl fencing
• Cleans gummy buildup from steering wheels
• Helps remove protective coverings from new cars
• Removes melted gum from dashboards
• Helps remove vinyl bed-liners
• Removes scuff marks from cars caused by shopping carts
• Displaces moisture from car wiring
• Spray on suspension gaskets to resist deterioration
• Cleans salt-impregnated ice from the soles of my Doctor Marten's boots
• Spray on a rag and wipe steering wheel and gearshift ***** to keep them grease-free and grip-able
• Lubricates rubber bushing
• Cleans gunk from electrical contacts
• Removes carbon residue from spark plugs
• Cleans bugs from rooftop cellular antenna
• Cleans
• Removes gum from floor mats
• Removes grime from cellular antenna to improve reception
• Cleans pin striping tape from car
• Cleans ignition wires
• Frees rusted glove compartment door
• Removes gum from floor boards
• Lubricates linkages on emergency brake release
• Cleans gum from door sills
• Removes crayon from dashboard
• Cleans sand from door joints
• Cleans spare tire mount under pickup bed
• Removes gum stuck in door locks
• Use on swamp cooler to prevent burnout or seizing
• Spray tachometer cables to ensure accurate readings
• Lubricates ***** on air conditioners
• Cleans gunk off snow chains
• Removes melted rubber from exhaust pipes
• Lubricates well crank handle
• Removes crayon from vinyl surfaces
• Removes debris stuck on floor mats
• Prevents oxidation on battery connections
• Removes pine tar from truck bed covers
• Maintains interior
• Spray on a rag and wipe window handles to keep them grease-free and grip-able
• Removes leftover adhesive residue from tape that holds camper shells to vehicles
• Removes road film from brake cables
• Protects cast iron brake rotors when storing vehicle
• Prevents rust on outside of door panels
• Drives moisture out of trunk locks
• Fogs interior of vintage motorcycle mufflers during winter storage
• Keeps car locks from freezing during winter
• Helps protect rubber trunk molding
• Prevents spray nozzles for windshield washers from freezing
• Drives moisture from DC auto batteries
• Drives moisture from electrical wiring in cars
• Protects electrical connections in car/truck engines
• Drives moisture from front struts
• Drives moisture from convertible top hinges
• Lubricates seat belt buckles
• Lubricates ashtray for easy sliding
• Lubricates 4-wheel-drive hubs to ease locking procedure
• Prevents noise on car window tracks
• Frees up sticking carburetor linkage
• Loosens slack adjuster locks
• Prevents antenna from freezing during winter
• Removes dog slobber from dash and seats in vehicle
• Cleans dirt from door latches
• Spray brake button under brake petal to loosen sticky brake lights
• Helps remove broken keys from locks
• Lubricates gears on hand-rolling car windows
• Keeps truck bed anchors rust free
• Lubricates convertible top zippers
• Lubricates automatic seat belt tracks
• Lubricates and cleans check-valves in pop-up headlights
• Lubricates trailer support cranks
• Penetrates stuck brake bleeder valves
• Lubricates car ignition
• Removes grit from windshield wipers
• Lubricates hood release cable
• Lubricates choke linkage
• Keeps cable on spare tire rack from seizing
• Cleans and protects brake shoe mechanisms
• Lubricates speedometer cables
• Lubricates locks on vehicle bike racks
• Penetrates stuck car hoods
• Cleans gunk from pistons
• Lubricates gas cap locks and levers
• Keeps air horn celluloid from sticking
• Lubricates swiveling chairs in minivans
• Frees sticky remote control mirror mechanism
• Lubricates air nozzle caps on tires
• Unsticks electric seats in vehicles
• Keeps pop-up auto lights operating smoothly
• Helps remove window tint
• Lubricates hydraulic lifts on truck bed cover
• Penetrates stuck radiator handle
• Cleans dead insects from radiators
• Lubricates zippers on zip-up car windows
• Cleans cup holders
• Lubricates hand-operated window cranks
• Lubricates choke levers
• Keeps transmission linkages operating smoothly
• Frees stuck fuel door cable
• Cleans and protects seat belt buckles
• Helps remove wire rim wheels that are rusted to axle
• Lubricates rusted oil pan plug
• Helps free stuck battery cables from terminals
• Eases removal of pinion shafts on old pistons
• Restores vintage door locks
• Eases removal of stuck spark plugs from engine
• Penetrates stuck fog light nuts
• Spray battery bolts prior to installation for easy removal
• Loosens rusted oxygen sensor in car exhaust pipe
• Stops squeaks in car strut mounts
• Prevents rust on inside of door panels
• Prevents rust on side trim
• Helps remove hand prints from truck bodies
• Stops squeaks on car doors
• Lubricates car door hinges
• Lubricates motorcycle chains
• Lubricates drive chain on motorcycles
• Lubricates throttle linkage
• Eases installation of rubber exhaust hangers on exhaust systems
• Lubricates auto hood latch
• Stops squeaks on tail pipe hangers
• Stops belt noise on automobiles
• Removes squeak from brake pedal
• Lubricates sun visors
• Stops squeak in alternator pulley
• Stops squeaking on windshield wipers
• Spray aging rubber grommets to eliminate squeaks
• Lubricates mounting bracket for alternator
• Stops squeaks caused by brake cable rubbing against chassis
• Lubricates cipher locks
• Removes wax from motor
• Spray on trailer hitch to prevent squeaks while towing
• Quiets squeaks on automatic sliding seat belts
• Stops squeaks on steering wheels
• Lubricates fuel line remote opener
• Spray inside radiator or fuel lines to slide them on easier during installation
• Protects rubber gasket around the sunroof
• Lubricates windshield wiper linkage
• Stops squeaks on clutch pedals
• Lubricates wire being pulled through a conduit
• Lubricates hydraulic tailgate lifts
• Lubricates automatic side view mirrors
• Eliminates squeak from fan belt
• Lubricates pneumatic door lifters on station wagons
• Loosens stuck butterfly valves
• Unfreezes car doors
• Keeps heim joints free on race cars
• Keeps winch cable lubricated and clean
• Lubricates stainless steel hood latches
• Lubricates convertible top gears
• Lubricates scooter lift
• Lubricates torsion bars
• Spray on rubber intake air ducts to ease installation of fuel injected engines
• Lubricates ball joints
• Lubricates rear shock absorbers
• Dissolves grease
• Drives moisture from flooded engine
• Spray on aluminum cylinder heads to prevent galling and cross threading
• Removes excess wax from rubber bumpers
• Keeps asphalt from sticking to dump truck bed
• Lubricates bearings in wheels on boat trailer
• Removes a Boa Constrictor stuck in engine compartment of cars
• Removes paint rub from another vehicle
• Cleans and protects windshield wiper blades
• Helps to insert cables into cable looms
• Lubricates control arm bushings on front or rear suspensions of autos
• Lubricates rubber wiring grommets to ease installation into fenders/firewall
• Shines car tires
• Removes tree sap
• Cleans PVC valves
• Cleans
• Dissolves grease
and the last time was this past summer when I spent a weekend in a really hot and humid area off the ocean. Don't know what's up with Lexus belts
[QUOTE=PandaGS430]Don't know if there is actually a solution for your squeeling other than to try a different brand belt. I realize you stated the belt is new, but when you start to hear the pig sound and your belt is new there obviously is a direct correlation to the belt. Maybe your belt was sitting in the shop sun beaten on a wall before it was installed on your ride....who knows?
btw....did you spray the belt dressing on the BELT? or did you spray it on the contact points of the belts where they meet the pulleys?[/QUOTE
I sprayed the belt dressing on the pulleys and the belt. I initialy changed the original belt with an aftermarket belt made by Continental Tire Co. That belt work fine, until winter came around. It squealed like a pig. I took it to the dealer and purchased an O.E. belt that belt worked fine the day they put it in. The next day, I started may car up in the morning, 25 degrees outside,, and it started to squeal. took it back to the dealer and they put belt dressing on it. It worked for a while, then the squealing came back. I have an appointment with the dealer this Saturday. I spoke to them on the phone and it probably need belt dressing.. Do have have to do this every winter?
my car does the same thing and i replaced my belt w/an OEM belt and it held up for a while (a few months), but the noise is back and i HATE it... it makes me feel like i drive a P.O.S. american car
im gonna give the the WD-40 a try...
Originally Posted by LB Lex
I had that squeeling when it's cold, so I sprayed the bolt that's in the center of the tensioner with WD40 and it got rid of the noise.
Which pulley is the tensioner? My squealing comes from the top pulley
