Limited Slip Differential
Old May 9, 2001 | 12:19 AM
BBD's Avatar
BBD
....BANNED! :-)
Question
ok the Limited Slip Differential from RMM or Ltune both would give the GS400 a better pick up ,, my question is Would it effect my top speed ,,,,,, or would my mid range be slower ,,, I remember reading one or the other gets effected thank you
Old May 9, 2001 | 07:52 AM
JacobT
Guest
Posts: n/a
The RMM unit is actually the Supra TT rear end with 3.76 gear ratio. You GS top speed is governed by the ECU at 150mph. Even with 3.76 ratio, your GS can go higher than 150mph, so it won't affect your top speed.
I don't think L-tune has the LSD. It's the TRD unit which is just the clutch section. You need to use your stock ring gear with the unit. So basically it'll give you better traction with the same acceleration and sfift point as stock ones.
Old May 9, 2001 | 12:21 PM
BBD's Avatar
BBD
....BANNED! :-)
alrighty then ,, nice info and thank you,,
Old May 11, 2001 | 11:42 PM
QBranchCars's Avatar
QBranchCars
BBD,
You may be referring to the L-Sportline LSD, which sounds similar to the RMM. Search under the keywords "limited slip" in the forum because we discussed this in great lengths a couple of months back.
Result recommendation was to get the TRD LSD.
lex400sc
Oct 28, 2004 03:13 PM
fireballs gs400
Performance
Apr 1, 2003 08:37 PM
stephen0917
Performance
Jun 12, 2002 08:24 PM
kyle3481
Mar 6, 2002 12:14 AM
itsallgood
Performance
Oct 26, 2001 12:48 PM
