Old Dec 16, 2014, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
D.I.Y. Oxygen Sensor Replacement
Old Sep 16, 2011 | 09:26 AM
  #46
mphsatty's Avatar
mphsatty
I do live in Memphis (PM sent).
No, didn't even think about an exhaust leak. Guess I'll just install the new sensor and see what happens with the CEL--then go from there.
Old Sep 17, 2011 | 01:18 PM
  #47
mphsatty's Avatar
mphsatty
This DIY works really well. The only problem at all was disconnecting the electrical connector. You really can't see it very well because it's almost flush with the edge of the dash. Just press down on a recessed arm (with a small, slotted screwdriver.
Old Oct 7, 2011 | 02:46 PM
  #48
95Bravo's Avatar
95Bravo
Bvance - your post saved me $400+ by DIY instead of bending over for the dealer. A lot of posts on O2 sensors, but your's was linear, detailed and easily understood. Thank you.
Old Nov 2, 2011 | 08:46 AM
  #49
averyt45's Avatar
averyt45
Thumbs up Bank 2 Sensor 2
i've been hunting this thing for awhile now. thanks man. how's it running now?
Old Nov 12, 2011 | 11:41 AM
  #50
alzimme's Avatar
alzimme
Just replaced Bank 1 Sensor 1 error. I got the sensor off of Rockauto.com for $34 shipped (came with the built in heater). Took about 2 or 3 days to ship. PB'd the heck out of it in the morning and then right before I wrenched it off. Granted this is the easiest sensor to get to, it took all of 10 minutes to do the swap. Took longer to let the PB work its way in and reset the ECU. Difficulty 1.5 out of 5.
Old Dec 2, 2011 | 04:28 PM
  #51
anakate's Avatar
anakate
Originally Posted by Rockero28
Okay, so my first question, is how do you know which is bad, since there 4 right? I guess I could take it to lexus and pay the $138 for the diagnostics, but is there a way to find out otherwise? Also, how hard is it really to do this? I am good at alot of things, but anything having to do with the "check engine" light, well I am not always too comfortable doing. but if it's not that hard, maybe i can. Or I can buy someone a 12pk of their favorite beer in echange?? I will buy the parts of course!
Rock
I go to Advanced Auto Parts every once in a while to make sure that the light that is on is for the same thing - my O2 sensor and not something else. It is free. Free. I started to feel guilty going there for just a reading so I buy some smelly thing. I'm sure the other auto part stores may offer the same thing. Call them.
Old Dec 4, 2011 | 12:57 PM
  #52
engin_ear's Avatar
engin_ear
Everything in Moderation
I'm not sure everyone is aware of this, but you can buy your own OBD2 code reader from Pep Boys or amazon.com very easily for under $100. I have this one and I like it:
http://www.amazon.com/Equus-3100-Inn...3031994&sr=1-9
I'd rather be able to read and reset my own codes rather than rely on the diagnostic capability of anyone at an auto parts store, free or not. Also remember why they are offering this service for free and why they are in business - they want to sell parts. So what may seem like it is in YOUR interest is actually in THEIRS.
Old Mar 10, 2012 | 05:44 PM
  #53
simplicity's Avatar
simplicity
Thank for this write up it helped out alot!
Old Jul 25, 2012 | 10:25 AM
  #54
clawmoolah's Avatar
clawmoolah
Wow I need help with my with my sensor anyone call help.? 2000 gs300 located in Brooklyn
Old Oct 16, 2012 | 04:44 AM
  #55
oddjobs's Avatar
oddjobs
Which are the best brand o2 sensors to buy?
Old Dec 10, 2012 | 10:42 AM
  #56
Dtwillis5's Avatar
Dtwillis5
What can a bad o2 sensor cause and what should the resistance be if I ohm it out?
Old Mar 6, 2013 | 03:44 PM
  #57
whytry's Avatar
whytry
I'm interested in these readings as well. My car isn't throwing the check engine light, but I have lost 12% in MPG all of the sudden and it has never increased. Been over 9 months now. I've tried everything else and nothing has fixed it. So if I can check Ohm readings that might eliminate the potential of buying new sensors and saving a couple hundred bucks on 4 new potentially unneeded parts...
Old Mar 15, 2013 | 11:41 AM
  #58
thatlowlex's Avatar
thatlowlex
Thanks for the post, this helped me tons!
Old Mar 19, 2013 | 01:35 PM
  #59
lexdubz's Avatar
lexdubz
I have a 99 gs300y check eng light came so I took for a diagnostic and the code said possible cause was loose sensor wire , blown fuse or O2 sensor how do iI check connections and fuse
Old Apr 10, 2013 | 10:01 AM
  #60
whytry's Avatar
whytry
How do I know which sensors are downstream or upstream? For example bank 2 sensor 2.
04 GS430 if that helps at all...
