Does 98 GS300 comes with VVTI?
Old Sep 8, 2004 | 07:53 AM
pawel's Avatar
pawel
Default Does 98 GS300 comes with VVTI?
I'm looking to buy 98 gs300 and do single turbo on it, but wanted to know if it has vvti.
Thank you
Old Sep 8, 2004 | 09:22 AM
Neo's Avatar
Neo
The One
Yes.
Old Sep 8, 2004 | 09:32 AM
pawel's Avatar
pawel
Originally posted by Neo
Yes.
did it changed from year to year?
Old Sep 8, 2004 | 09:34 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
No. All GS models 98+ have VVT-I
Old Sep 10, 2004 | 09:15 PM
LEXTECH's Avatar
LEXTECH
'98 was the first year VVT-i was introduced. The '98-'00 GS300-400 have better acceleration than the '01-'04 GS300-430 the newer models are "drive by wire". Who know maybe the '05 third generation GS might out perform the 400? It's going to be pretty damn tuff.
Old Sep 17, 2004 | 01:32 AM
rominl's Avatar
rominl
exclusive matchup
just to be clear, the "better acceleration" probably refers to the better throttle response. i drove the gs430, sc430, and the pre 04 ls430. they all have the same problem on acceleration, very bad response. the drive by wire system is just weird i think
Old Sep 17, 2004 | 08:22 AM
LB Lex's Avatar
LB Lex
I believe all GS400/430s are drive by wire, the difference in throttle response is due to the computer. My 99 has a cable going to the throttle, and if I pull on it the throttle will not open unless the engine is running.
Old Sep 22, 2004 | 11:40 AM
tytgs300's Avatar
tytgs300
Default '98 was the first year VVT-i was introduced
does anyone know if this engine uses timing chain or belt ? one mechanic told me timing chain the other said belt. tks
'98 [inline-6] was the first year VVT-i was introduced
Old Sep 23, 2004 | 01:00 PM
LB Lex's Avatar
LB Lex
Belt.
Old Sep 26, 2004 | 05:22 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Post Cable to the throttle
Just in case you guys were wondering why the early GS' had a cable going to the throttle body. It was for "Fail safe" Just in case something goes wrong. The check engine light would come on in the dash. And the car would be in what is known as "Limp home mode". When you step on the accellerator, you would have 30% throttle manually through the cable. Meaning you would only have 30% throttle max. Just enough to get you home, the dealer or your personal mechanic. The later models have no cable. They are a true fly by wire set up. You will still get 30% throttle in limp home mode via an electric motor hooked up to the throttle body.
Will
Old Sep 26, 2004 | 05:34 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Will
FL1PP3D
Aug 26, 2007 02:59 PM
silent1pro
Jan 17, 2007 04:20 PM
DoMaMuy
Mar 8, 2006 09:03 PM
Jmai22
Aug 21, 2004 07:41 PM
LB Lex
GS - 1st Gen (1993-1997)
Sep 28, 2002 01:46 PM
