trd air filter
Old Jul 20, 2004 | 10:31 AM
Rockero28's Avatar
Rockero28
Lightbulb trd air filter
Anyone know how to clean the TRD air filter?? Can I just use water or does it have to be a special solvent and if it is.. where do I get it?
Thanks in advance
Rock
Old Jul 20, 2004 | 10:41 AM
lexforlife's Avatar
lexforlife
if it is like the toms ram air high flow i have which is a foam type , unless its black from grime just use air and blow it out if its black or brown with grime then imerse in water very very little soap and let air dry before reinstalling DO NOT USE ANY OILS on it if its foam
Old Jul 21, 2004 | 05:49 AM
ChrisK's Avatar
ChrisK
TRD filter is like K&N. It is oiled cotton type. You can buy TRD cleaner and oil. Probably you also could use K&N cleaning kit.
Old Jul 21, 2004 | 10:05 AM
joel5150's Avatar
joel5150
Rockero28
Don't use compressed air as it can damage the material and allow larger particles to get into the system. The best thing to do is lightly bump it on a hard flat surface to remove any bugs/large dirt particles.
Then you can wash it out with water and Simple Green. I sprayed 100% Simple Green on mine and let it sit for bout 10 minutes. Then I used the spray setting on my sink to rinse it out. Did that a few times and then let it air dry. You need to get the oil for it, but use very little. I used a fine mist and sprayed it about 3 or 4 times.
Old Jul 21, 2004 | 11:06 AM
Rockero28's Avatar
Rockero28
Unhappy trd filter
Well, I washed on soap and water.... then I used an air hose sparinggly blow dry it and let it sit in the sun.. It's clean now, but did I screw it up now?? It looks to be fine, but is it?
Rock
Old Jul 21, 2004 | 11:07 AM
joel5150's Avatar
joel5150
I am sure it is fine if you were careful. Just don't go full blast with the air and you should be fine.
Loadedes
Oct 1, 2013 08:34 PM
Rockero28
Aug 17, 2007 11:19 AM
mcgong
Performance
Jul 9, 2003 01:53 PM
