another happy 3.76 LSD mod
Originally posted by nudderGS400
ChuH,
890 seems high. I paid 700 shipped and that is a tad on the high side, but it was from a car with 42K miles on it. I hope 890 was shipped at least!
Buyers for used TT units need to be patient, look on www.supraforums.com and buy from someone who appears legit, lots of posts, been a member a long time, etc. You should be able to get one or less than 800 shipped to you.
Good luck.
ChuH,
Good luck.
Chu...
Must be an auto from a TT from 93.5 to 98 only. The manual does not have the correct gearing for your car.
Do a search you will find a ton of info on the specifics of the supra LSD.
Originally posted by ChuH
I found a place in Australia that has a Supra LSD in stock want to sell at about $890. Is this about the price most of you paid for a used LSD?
Originally posted by DaveGS4
It will slow your car down. Unless you have forced induction or some other power adder (nitrous) you don't really need LSD and your gear ratio on a GS3 is already higher than the Supra TT (3.76 vs 3.9x in a GS3).
so dave, wut your saying is a stock gs has 3.76 gears ???
Originally posted by T.L.W.
i tried search but didnt get the answer i wanted or i didnt use the right words
but when you have the supra lsd and you are on the highway (65-100 mph)
what's your RPM
what's your RPM
with the 3.76 gearing i believe it's about 300rpm higher?
Originally posted by rominl
on a stock gs4 at 85mph it's about 2500rpm, at 90mph it's close to 3000
STOCK: 60 mph = 1950 rpm 80 mph = 2650 rpm
3.76 LSD 60 mph = 2250 rpm 80 mph = 3000 rpm
Bear in mind that this is with my tire/wheel size and they are approximate rpms.
Originally posted by bitkahuna
Shipping will kill you - the diff is VERY HEAVY.
Originally posted by FutureGS400
On the freeway down to TM Engineering to have mine installed and then again on the way home after the LSD install, I recorded the following RPMs:
