Code retrieval help - strange situation
Ive got a 93 SC400, all stock 258k mi, fully rewired engine harness with removed EGR system (although the solenoid is still plugged in and hasn't been a problem), that has been back on the road with its fresh timing belt now for over 1000mi with no problems
The age old battery died while I was out of town for 2mo and I replaced it with another that isn't the same physical size but is close enough in Amp ratings and it seems to work just fine - I'll be replacing it with a correct one once funds are available - I've only driven it around my neighborhood since this and it seems to run just fine
Before the battery change, the SES light would come on/flicker intermittently - I now have a steady SES light since changing the battery
I just did the code retrieval procedure jumping the pins at the port under the hood
Here's the strange part - the SES light didn't blink, the O/D light blinked a code 63? - the SES light never blinked
When I did the timing belt , I also had to fix my engine harness in a few places - no big deal for me, its been fine other than the O/D light flickered a couple of times that I noticed for no apparent reason
Also, removing the EFI fuse to clear the codes didn't turn off the SES light
Anybody have a clue as to what's going on here?
I'd appreciate any insight anyone may have
I do have the TOYOBD1 tool, if you want to try that maybe we can get together since we are relatively close it sounds.
MemzaEyz
12
12-08-13 01:52 PM
