Oil pan gasket replacement
Old 08-09-16, 01:50 PM
Northof49
Northof49's Avatar
Default Oil pan gasket replacement
Hello - new to Lexus and now I own an '03 SC430. After installing a new rad and with the engine cover off, the oil pan has signs of a "slow leak" . The pans bolt arrangement has at least two or more that are located under the frame or crossmember. A bit snug to fit a wrench in and then the question of torque to the right spec later. Is there a "trick" to removing / and reinstalling them?
If it means removing the cross member does it affect the geometry? And how do I deal with it?
I've also heard that a if the pan is aluminium and not steel, a liquid instead of a regular gasket is required.
Looking for answers in BC
( a dream to drive!)
Last edited by Northof49; 08-09-16 at 11:31 PM. Reason: Clarity - more detail questions
gemineye
04-01-22 06:21 AM
Denvermgb
10-30-13 11:54 AM
1eightySX
09-30-12 08:23 PM
SISMO817
GS - 1st Gen (1993-1997)
11-05-07 08:01 PM
jpw
08-17-07 06:07 AM
Quick Reply: Oil pan gasket replacement
