HELP vss auto to manual ?s just clarifying some wiring
my auto to manual swap guys.. just want to clarify with the wiring
1: safety switch i need to just jump/ or connect the black and black/white wire together(i know that will make it so i can turnt he car on without the clutch in
2:the reverse light the w58 has a two pin connector and the auto has a 10 pin connector
ill need to either just take pin 4 and pin 9 from auto connector and pin them to the w58 sensor on the trans if i dont find a connector
for my vss thats where im stumped on is hte vss connctor on the auto same as the w58 connector is it a straight plug and play i cant find anything about it
thanks in advance
thanks in advance
