post all your questions and answers is this thread that has to do with SC fogs lights. ex....projector retrofit, How to's ,restoring and custom fit like the dodge ones and others that you think will work
First question Can IS300 fogs work with our stock housing like the ES models do?
I am not sure if those particular ones will fit, but I was reading somewhere awhile back that Dodge Intrepid ones fit, with little or no modifications. I think there is a link of this being done.
I've got a question. How do I get my foglights to turn on with the parking lot lights? Or just by themselves completely? I have a 1997 SC300 and the foglights only work if the lowbeams are on. I'd like to be able to have complete control of the foglights. Anyone have any suggestions?
edit: Mainly want to do it so I can use the fogs as parking lot lights...as the other "parking lot lights" don't do anything...
You will have to Wire them in separately & put them on their own System & switch such as when you install xenon driving lights.
Hey guys, sorry to revive an old thread but didn't wanna start a whole new one for my question just yet.
I want to see if anyone has Delined the 93 corner lights, I vaguely remember a thread I found 6 months ago mentioning it, but they may have not had success.
My headlights, and high beams will both be Delined, so i'm either going to find a way to Deline them to match, or nix them all together....
My eventual plans/ options are
1. retrofit a projector into housing and Deline Lens...
If deline is not possible i'll either
2. use corner lamp housing to retrofit projector. sand down housing smooth, paint black, remove lens and rock fogs the way the IS350 does with no outer lens.
3. bolt up a projector without housing and just use black plastic materials to fill gaps.
4. Remove lamp all together leave a hole in its place.
the thread I found a few months back did something similar with a projector just bolted up... I cannot for the life of me find that thread again :[
thanks for the help in advance. AND if you think you know of or can find the thread i'm referring to I'd GREATLY appreciate a link.
I have a problem, my 97 sc fog lights don't turn on. Does anyone know where I could find the fuse to the fog lights? I want to make sure the fuse is not missing before I try to put new bulbs in.
