Whats your number??
Old 11-11-12, 07:54 AM
megamax
megamax's Avatar
Default Whats your number??
as the title states. i want to know what your afr's are??
-at idle
-wot
-and crusing
mine now seems to be idle and crusing at around 14afr with the fuel pressure adjusted at 40psi on idle.
when i go into wot i noticed it dropped down to 10(which is healthy imo). for my nissan. but ive heard of other members running 10 afr in idle. so i need some numbers please people, i know it's a sleepy boring sunday. but help me out.
my mods
-wally
-hx hc1/hx35 turbo with a new minty .65 ar hotside
-full 3" exhaust
-aero adjustable fpr(to stop that nasty lean).
and thats it for now!!
Old 11-11-12, 08:21 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
A good rule of thumb Jim, is to use or set it around 42 psi. See what happens then. Glad you have been able to troubleshoot this thing a little further.
Old 11-11-12, 09:18 AM
spoolxexo
spoolxexo's Avatar
Also, make sure the simple thing are changed like the fuel filter. That will make the car lean if it's all clogged up.
The factory Toyota ECU does a good job, 14 idle/cruise and 10 at WOT are fine.
Oh and go to my Pre-OBD Datalogger thread and get it now!
Old 11-11-12, 11:20 AM
megamax
megamax's Avatar
changed the fuel filter eons ago. but that is something people do usually neglect. and i will try out 42psi.
but bump more answers people!!
Old 11-11-12, 02:14 PM
soarer13oy
soarer13oy's Avatar
Im at 14-15 afr for idle and cruise to be a bit more fuel efficient and 11.2s wot. Running on a map ecu.
Old 11-12-12, 10:30 AM
megamax
megamax's Avatar
bump moar people!!
Old 11-12-12, 02:05 PM
chnk
chnk's Avatar
14-15 idle and cruise, WOT is around 10 think i saw a high 9 once,
Old 11-12-12, 06:04 PM
SC300_704
SC300_704's Avatar
mines idle and cruise at 14.3-14.9 and WOT is around low 10's-low 11's also seen high 9's a few times lol. time for a tune.
Old 11-13-12, 10:12 AM
megamax
megamax's Avatar
Idealy, 10 at wot is where u want to be correct?
Old 11-13-12, 12:34 PM
preston145
preston145's Avatar
10 at WOT is too rich, you want be in the net of low 11's on pump. Me on e85 i sit around 12.
Old 11-13-12, 01:18 PM
Ali SC3
Ali SC3's Avatar
the stock ecu especially the turbo ones will do solid 10 in boost, which when you have the option of tuning is a bit rich, ideally you want it in the mid 11's but 10:1 is correct for a stock setup and yes it is on the rich side.
I get 14.7 pretty consistent at idle, and drops to 10 in boost. alot of poeple will use a piggyback to pull out some fuel at wot till it gets in the 11's and if you have a map based ecu this will also help raise boost cut some.
sumolexus
RX - 1st Gen (1999-2003)
18
10-26-12 11:19 AM
Sturds
04-07-12 08:31 AM
redforeva
18
09-22-11 02:51 PM
nicola
04-10-05 11:59 PM
Quick Reply: Whats your number??
