Bleeding new clutch mc? Special procedure?
Old 08-23-12, 04:34 AM
Vwpride12
Vwpride12's Avatar
So the way you have the tob situated is the port for the "out" facing up inside the bell housing?
Old 08-23-12, 11:57 AM
charley240
charley240's Avatar
Yes, the out port faces uP
Charley
Old 08-23-12, 12:49 PM
Vwpride12
Vwpride12's Avatar
Well...if you had an access point I would try and put some tension against the throw out bearing while doing the two person bleed method, with a prybar or something.
Old 08-24-12, 12:41 PM
mikes7ke
mikes7ke's Avatar
I have a similar setup on my LS400. I also didn't bench bleed it. Took forever, but works just fine now. As long as you have no leaks keep bleeding. You'll get it eventually.
Old 08-24-12, 02:20 PM
charley240
charley240's Avatar
There is no access unless removing the whole transmission and my brother and i have both seriously bled the thing to death.
I called up tilton yesterday, he suggests removing the spring from the pedal. Im going to give that a shot. He also says that the 5/8" bore of the stock MC is too small, not displacing enough fluid to the tob. This seriously sucks. Because the manual recommends a 3/4" bore MC as well.
Wish me luck. Lol
Charley
Old 08-24-12, 08:50 PM
Vwpride12
Vwpride12's Avatar
Good luck!
Old 08-25-12, 03:08 AM
XplicitlyR
XplicitlyR's Avatar
I know the difference between blessing brakes and a clutch is not different except the speed of the pumping. For the clutch go slow, use your hand and go slow.., don't do fast pumps.
1997Soarer
09-29-17 10:30 AM
Salil022
30
05-29-14 07:04 AM
pnyboy27
13
08-04-08 01:57 AM
95 Integra
12
12-13-05 07:28 PM
5spdSC300
18
05-26-05 07:59 PM
Quick Reply: Bleeding new clutch mc? Special procedure?
