please help!!!!
Old 05-02-12, 10:17 AM
kevinsc300
kevinsc300's Avatar
Default please help!!!!
My 1995 sc300 Shut off during idle, when I start up the car the RPM right about 1500 then it drop down to 1000 and keep going down to 0 that time it shut down.
I tired to clean IAC valve, put it back together it didn't drop down this time but it unstable, RPM neddle going up and down make the engine shake so bad.
Please help
Old 05-02-12, 11:34 AM
CDN-TEX
CDN-TEX's Avatar
Did you take the throttle body off to clean IACV. If you did, check all vacuum hoses. Did coolant run into the spark plug alley. Did you fool with the TPS, when I remove my TPS I get similar idling. Give little more info of what you did before this started.
Old 05-02-12, 11:37 AM
CDN-TEX
CDN-TEX's Avatar
...also don't feel bad when they move this thread to appropriate forum.
Old 05-02-12, 11:42 AM
Tabaka
Tabaka's Avatar
If the RPM is going up and down at idle it's usually a sign of a bad or uncalibrated TPS sensor.
Old 05-02-12, 01:53 PM
GS4_Fiend
GS4_Fiend's Avatar
Clean Throttle body, could be carbon buildup. Check for vacuum leaks.
Old 05-03-12, 12:18 AM
kevinsc300
kevinsc300's Avatar
After I took off the IAC valve to clean, then put it back. It's go up to 2000 RPM then it's stay there not go up or down.
It only stay on 2000 rpm when idle in park gear or neutral gear, if I go for reverse gear or drive it will drop down to 1000 RPM.
Old 05-03-12, 12:38 AM
AnonymousG
AnonymousG's Avatar
Before you reinstalled the IACV did you screw the plunger back all the way in?
Old 05-06-12, 08:30 PM
kevinsc300
kevinsc300's Avatar
yes, i did put it back in correctly.
Do you think it's could be Oxygen sensor or the coolant sensor?
KTGS300
06-10-18 04:05 PM
JustChill
03-07-12 01:19 PM
mike510
01-16-12 10:42 AM
RLGS300
08-13-11 03:06 PM
andres-eh2
RX - 1st Gen (1999-2003)
10-22-09 06:51 AM
Quick Reply: please help!!!!
