350Z trans adapter?
Old Feb 6, 2014 | 01:40 PM
  #346
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I don't see how that tremec is going to fit on anywhere easily but looks very interesting.
yeah the xterra shifter setup looks promising, I just wonder how much has to be changed inside the trans to accomodate that setup. if its just the shifter arm and you can get all the parts at a junkyard then its like they put a solution on there for swapping into different cars, which technically is what they did with the Xterra its the same basic trans. I don't have a 350z trans or any xterra parts, so I will leave it up to you guys doing the ground breaking work to get all the details on it sorted.
or on second though use the whole Xterra 2wd trans.. lol. gears would probably be very unique.
*edit*
Xterra 2WD & 4WD
4.368 2.518 1.743 1.283 1.000 0.769
350z
3.794 2.324 1.624 1.271 1.000 0.794
Old Feb 6, 2014 | 03:26 PM
  #347
blackkarma's Avatar
blackkarma
The tremec goes where the inspection cover is located and extends 4" behind that.
Old Feb 6, 2014 | 06:53 PM
  #348
babowc's Avatar
babowc
Originally Posted by iridebmx
as much as i want to keep my cluster i am probably going to go with speedhut gps gauges to replace the entire cluster.
its that or try to somehow incorporate your rear abs(which doesnt have a vss... OB1 at least) with a abs speed sensor signal and hard wire it to your speed sensor plug on your harness.
orrrr a driveshaft speed sensor but i dont know how that would tie into a oem gauge....
Does the Dakota digital box not work to translate the signals?
Old Feb 7, 2014 | 02:12 PM
  #349
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
nice, has anyone done this yet or has outlined what else is needed or this breaking ground also.
Old Feb 7, 2014 | 04:41 PM
  #350
blackkarma's Avatar
blackkarma
The standard tremec shifter has been tested on a swap done on a mkiii. Worked without issue you will just need to install the shifter socket and bushing which means removing the shift rod. The socket slides right on. The t56 magnum parts are the ones you are looking for just remember u will need to rig up a way to mount the shifter but that's the easy part. I talk to sikky about making it to fit the cd009 but was able to pursue an custom work at this time. I will be talking to a buddy of mine who also does Cnc work an see if he will at least make a mount if not the whole thing.
Old Feb 28, 2014 | 03:55 PM
  #351
Kris9884's Avatar
Kris9884
I like the Xterra idea, it seems to be in a much better spot, although the angle of the shifter may be awkward? I want to try this but don't feel like laying in gravel at the picknpull right now lol. They only charge $80 for the transmission if you pull it yourself and get to take everything associated..
Old Mar 2, 2014 | 07:13 AM
  #352
1uzme's Avatar
1uzme
Anyone notice Collins adapter for the 1uz to z33 trans, the trans adapter doesn't clear the stock ls400 headers? It hits both header to exhaust flanges.
Old Mar 22, 2014 | 10:37 PM
  #353
jbrandon's Avatar
jbrandon
Aapter components no longer available, thanks!
Old Apr 9, 2014 | 08:02 PM
  #354
iridebmx's Avatar
iridebmx
finally got my gopro back. better video this weekend with cellphone speedo
https://www.youtube.com/watch?v=Axpl...ature=youtu.be
Old Apr 9, 2014 | 11:08 PM
  #355
flubyux2's Avatar
flubyux2
Anyone run the maverick adapter components yet?
I'm a lot more interested in their flywheel since its one piece in the picture. It uses a replaceable friction surface but that just makes me question where replacement parts come from. If its an off the shelf rps or fidanza part, great. If its a custom unit available only thru maverick, that's bad. I want to avoid expendable parts with proprietary design.
It is nice that it allows 350z clutches.
Btw, I'm very curious about the ikeya formula shifter. I'm wondering if this will eliminate the z33 shifter issues since its not an h-pattern that requires the lever to be mounted in the oem socket.
Old Apr 18, 2014 | 02:06 AM
  #356
estomax's Avatar
estomax
the tail housing kit for xterra is 32130- CD100, its 310$
anyone brave enough to try it yet? i wonder if this means i also need a different length driveshaft..
Marko
Old Apr 18, 2014 | 06:43 AM
  #357
Halon's Avatar
Halon
So that will just bolt up to the 350z trans? How many inches we talking about saving with that? Any sort of linkage that needs to be used with it as well?
Old Apr 18, 2014 | 07:03 AM
  #358
iridebmx's Avatar
iridebmx
Buying that whole tailshaft is unneeded.
You need to buy the whole 'shift control' setup on the top of this page. I have personally taken my trans apart and our shift rod looks to be the proper length for this setup. In the blowout on that link the shift rod ends exactly where my trans did, in between the two plungers. The shifter connect that we all shortened on our extended shift assembly connects to it. If you buy the x-terra 4cyl. 2wd shifter it deletes the extended shifter and part #32844M replaces it inside the tail housing. And in the end moves the shifter all the way to the beginning of the cover plate. my guessimate would be 4-5 inches forward
Old Apr 18, 2014 | 12:44 PM
  #359
Halon's Avatar
Halon
I see, so 32844M replaces the extended shift rod I guess I'll call it on the 350z trans, basically dead ends it so it's shorter. Then remove that black cover on the 350z trans and replace it with 32145. Shifter goes right down through that now, to link up with the trans. Interesting. So does this setup retain the reverse lock-out feature where you have to push down to get into reverse? I may have to hit up the junkyard by my house and see if they have an Xterra sitting out there.
Old Apr 18, 2014 | 01:07 PM
  #360
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I would think it would have the reverse lockout because I have driven a 6 speed xterra and it has a reverse lockout. It was a 4x4 but I couldn't imagine the 2wd not having it. looks like there is a spring in there so it should have it.
I think it will be easier to start from the xterra spot and bend a custom shifter than to bend a shifter back from the 350z spot.
Hopefully someone gets a hold of one soon and tries it out =)
how hard can it be to find a manual trans 2wd xterra. probably the 4x4 has a similar shifter setup but not the tailshaft.
