No start when cold problem. help im stomped
Old Feb 2, 2012 | 03:48 PM
TTslug's Avatar
TTslug
Default No start when cold problem. help im stomped
the car is a 1995 sc300 w/ 1jzgte - non vvt engine. the swap was not done by me, and the guy who did it, made his own harness.
the car will not start when cold. it just cranks and cranks, if you do get it somewhat started. it runs stupid ruff and crappy until it starts to warm up. while the car is cold and barely running, if u tap the gas it dies right away. but when the car warms up, your good to go, runs prefect. im lost here. we swapped out the coolant sensor. with what we think was a good one, but no change, swapped the map sensor no change. could the timing be off a tooth? when the car barly is running it is rich. but i don't get how it does it just while cold
also, the car has a fmic. thats it. rest is a stock 1jz swap from a soarar.
please anything will help. i need my car running again lol
Old Feb 2, 2012 | 03:53 PM
GS4_Fiend's Avatar
GS4_Fiend
check your fuel pressure during the morning and see if it's within specs. I suspect fuel starvation.
Old Feb 2, 2012 | 04:18 PM
TTslug's Avatar
TTslug
i will check it tomorrow morning. but why would it run warm then?
Old Feb 3, 2012 | 12:04 PM
TTslug's Avatar
TTslug
seemed ok, i don't unstand how it could be fuel, once i got the car running, and it warmed up, the car ran prefect. boost, rev everything was good. i just can't get it to start.
Old Feb 3, 2012 | 04:23 PM
TTslug's Avatar
TTslug
ended up being something in the wiring from the guy who did the thing. i squeezed some wires and poof now it works every time.
JH48
May 24, 2019 05:32 AM
jeffbarn
Jun 27, 2011 09:34 PM
immax01
Nov 29, 2010 09:04 PM
11ballin11
Maintenance
Jul 30, 2009 05:06 PM
