ecu pin out help!
Old 10-04-11, 03:18 PM
flipboi
flipboi's Avatar
Default ecu pin out help!
i have a 92 sc300 that the ecu was going out and it would randomly die or wont start. the ecu didnt pull up any codes tho. i used my 95 ecu for temp and it worked. but since i switched it, the o2 sensor cel is on. i think the pin location for the o2 sensor are different on the 92 compare to the 95... any one have the ecu pin outs for the different years? maybe i can just relocate the pins if it is the case...
Old 10-04-11, 04:01 PM
turbodremz
turbodremz's Avatar
92-95 should have the same ecu pinout...sounds like your bad ecu just wasnt doing its job at all. Have you tried a new o2 sensor?
Old 10-05-11, 06:04 AM
99SC42
gte & na-t
99SC42's Avatar
^No 92-94 EcU are PNP interchangeable
95 ecu will plug up but O2 sensor are different so it's not PNP you will have to rewire the 02 sensors
96-97 are interchangeable and PNP
98+ is a whole new scenario they changed the Ecu design the ecu plug looks like the 1jz ecu plugs.
So a 98 ecu from a 2jz sc will never work on 97 and under.
Old 10-05-11, 07:10 AM
turbodremz
turbodremz's Avatar
^^Really?! Huh, learn something new every day. Sorry OP for the misleading info I posted.
Old 10-05-11, 07:32 AM
99SC42
gte & na-t
99SC42's Avatar
Yes Chris 95 is the weird year, and the body plugs got changed in 95 so if you put a 92 engine and harness in you 95 your oil level , oil pressure lights will stay ON till you move the 2 wires at the correct location .
I had that happen to me, live and learn new things everyday!
lextout
12
09-09-17 02:00 PM
Zimzimmer
GS - 1st Gen (1993-1997)
11-28-15 07:24 PM
AJCady
SC- 1st Gen (1992-2000)
03-21-15 09:34 PM
sxylxy
12-22-02 04:17 PM
LOTC
03-27-01 09:29 PM
Quick Reply: ecu pin out help!
