GTE wont start after engine build. No Spark, help please
Old 01-09-11, 06:09 PM
  #31
trufanatic
trufanatic's Avatar
I have another question.
I am getting some serious vibration in the back of the car. Is there a certain way the drive shaft should bolt together or does it just bolt together? that vibration was never there. after 30 mph, she just shakes and its just in the back of the car so im assuming something with the driveshaft.
Old 01-10-11, 08:07 PM
  #32
cartmill
cartmill's Avatar
yes you can bolt the driveshaft in crooked. the rubber "biscuit" (vibration isolator) can be a little strange when you're bolting the driveshaft to the diff. look at a picture of the driveshaft in the FSM to see which way the bolts go, and also make sure that when you bolt it in, that the driveshaft splines are seated securely into the diff/biscuit.
Old 01-11-11, 09:36 PM
  #33
1sxyrxy
1sxyrxy's Avatar
wheels tight?
Old 01-17-11, 12:25 PM
  #34
magneti
magneti's Avatar
update? let us know the latest.
Old 01-17-11, 01:49 PM
  #35
Klaus
Klaus's Avatar
Also on the vibration check that the carrier bearing is installed correctly and the spacers are where they should be
Old 01-17-11, 03:20 PM
  #36
93MSB
93MSB's Avatar
^what he said
check and make sure the adjusting washers are inbetween the driveshaft and body
NOT between the bolt and driveshaft
if you pm me your email i can send you the service manual pages on the driveshaft
MongooseGA
39
01-27-15 06:52 PM
INCLINEDI
13
08-02-12 12:47 PM
Toughguy48
SC- 1st Gen (1992-2000)
10-25-10 10:14 PM
breakb
Maintenance
13
02-10-09 06:06 PM
youforia
02-07-06 11:46 AM
Quick Reply: GTE wont start after engine build. No Spark, help please
