wont go into gear...
I just finished my 95 sc300 swap. same stock 2jzge motor with 120k miles. f1 stage 2 clutch. and old original 5 speed tranny. Ive been driving around for the past 2 days put 100 miles on it. and then on the way home the car started vibrating a lot everytime i stepped on the gas. As I made a right turn I put it in second and then the car just makes a loud grinding noise towards the back like the differential teeth got all ***ked up so I pull over into a gas station and try to drive forward and it gets louder and really rough.
I wait for my friend to come with a truck and as I try and reverse it makes the same noise and vibration then just stops..
So I put it in first and drive down the street slowly towards home (which was a block down) and then everything was ok and smooth again. Its puzzling in my head...
A/ I though maybe it has a welded diff. and the ticks broke off and got into the teeth or
B/the teeth is a broken and grinding against eachother.
But why would it all of a sudden stop and run smooth as if nothing happen..
PLEASE HELP!
PLEASE HELP!
rajbertel
07-21-15 09:28 AM
klepto2
Performance & Maintenance
06-23-09 01:47 PM
