Ultimate 1uzfe W58 Conversion Thread! (LOTS OF PICS!)
Old 04-10-10, 08:30 PM
  #166
jcat_350
jcat_350's Avatar
hey man excellent work. I may be looking to get this done soon. Does it throw a CEL or anything like that? Any other things that would keep it from passing an inspection?
BTW, willhickey, it's quantum-auto.com.
Old 04-10-10, 09:17 PM
  #167
RedPhoenix
RedPhoenix's Avatar
No CEL confirmed on 95 and below, 96-97 soon. OD light flashes when speedosensor is plugged in, but I pulled the bulb.
Old 04-12-10, 06:08 PM
  #168
T-Lex
T-Lex's Avatar
Maybe I missed it, but do your reverse lights work?
What about your cruise control?
Old 04-15-10, 11:01 AM
  #169
RedPhoenix
RedPhoenix's Avatar
Reverse lights worked until I crushed the clip on a speed bump, havent fixed it since haha.
Cruise control, no, didn't try to hook it up, got rid of it instead.
Old 04-20-10, 11:38 PM
  #170
lev00221
lev00221's Avatar
Red Phoenix,
What did you do regarding your differential? Are you using the stock SC400 differential? Stock SC300 5spd differential? Other? What RPM's are you at when cruising 70 mph? I am going to convert my 98 SC400 VVTi to manual but I am unsure what rear end to use. Any advice would be much appreciated.
Thanks and great writeup!
Sincerely,
Luis
Old 04-21-10, 04:39 AM
  #171
RedPhoenix
RedPhoenix's Avatar
using the 3.92 right now. I wouldnt go any shorter than this, to me a 3.92 is short for highway (3k rpms around 70). The 3.26 you have may work nice (or be too long). I think the 3.73 from the Supra would be perfect.
Old 04-21-10, 09:00 PM
  #172
SC'd SC400
SC'd SC400's Avatar
More and more of these popping up....NICE!
How is yours coming along MongooseGA?
You will be fine with the factory rearend but I plan on going to the 3.73 Torsin in a bit.
Old 04-21-10, 09:17 PM
  #173
MongooseGA
MongooseGA's Avatar
My transmission ended up getting stuck in gear and I'm trying to figure out how to fix/replace it.
If I'm not mistaken, you were able to get the MKIV shifter on the MKIII tail shaft, correct? That's what I'm banking on if I end up using my same transmission.
Old 04-21-10, 10:34 PM
  #174
RedPhoenix
RedPhoenix's Avatar
We are actually testing out a MK3 W58 in an SC400 really soon (T-minus 1 month). And we might get away with a simple shifter extension... so we shall see!
Old 04-22-10, 04:16 AM
  #175
SC'd SC400
SC'd SC400's Avatar
No I wound up going with the SC300 W58 do to the adapter not reaching certain shift points.
Old 04-22-10, 04:26 PM
  #176
BartleDoo
BartleDoo's Avatar
Old 04-25-10, 10:03 AM
  #177
TheRonTom3
TheRonTom3's Avatar
Any confirmation on if you can get rid of the CELS a 97+ will throw
Old 04-26-10, 11:58 AM
  #178
RedPhoenix
RedPhoenix's Avatar
The wiring isnt done on that vehicle. Soon as I know I will post it up.
Old 04-30-10, 08:23 AM
  #179
fleishelja
fleishelja's Avatar
+1 on 97+ cel. I have a 97 and want to do this real bad but I unfortunately have emissions so...
Old 05-02-10, 07:37 PM
  #180
AusSC400
AusSC400's Avatar
RedPhoenix, such a good read man!
I am doing a conversion at the end of this year, but am using the 6spd T56, a guy on my forum in Aus makes kits with the adaption plate and that, really looking forward, just hoping it's not a whole lot different to your setup.
Still having lots of fun in it? I bet you are!!
Quick Reply: Ultimate 1uzfe W58 Conversion Thread! (LOTS OF PICS!)
