oil leak from distributer
Old Jan 5, 2008 | 12:17 AM
thebadz32's Avatar
thebadz32
Arrow oil leak from distributer
What can i do to fix this? just a new gasket do i have to pull the intake to pull the valve cover??? need help before i decide to get into this.
Thanks
Old Jan 5, 2008 | 07:18 AM
DryBlaze's Avatar
DryBlaze
Most likely the O ring but if there is oil around your valve covers I would replace the gaskets as well.
Old Jan 5, 2008 | 03:16 PM
Zeal3's Avatar
Zeal3
its most likely the O ring i changed mine in 30 minutes.
for a whole pack it cost $3 at autozone.
oh and theres a write up on how to do it.
Old Jun 6, 2008 | 09:31 AM
KoSC300's Avatar
KoSC300
i think i need to change my O-ring as well, have alot of build up by my distributor. wheres that write up at? i know i know, im searching as i type.
Old Jun 6, 2008 | 09:36 AM
5sp_jzz30's Avatar
5sp_jzz30
how to change the dist o-ring:
1. put the motor on tdc
2. take off the distributor cap
3. the rotor will be at the 1 o'clock position when the motor is on TDC
4. remove the 12mm nut and pull out the whole assembly
5. replace o-ring and reinstall distributor
6. after reassembly use a timing light to make sure the ignition timing is right.
good luck
Old Jun 7, 2008 | 01:39 PM
IS_Sunny's Avatar
IS_Sunny
Distributor O-Ring leak?
Old Jun 7, 2008 | 03:22 PM
Zeal3's Avatar
Zeal3
yup thats from the distributor.
better fix it before it damages ur alternator. bcs thats just adds on to the work.
Old Jan 14, 2014 | 06:03 PM
ScWift92's Avatar
ScWift92
Thanks
hate to bump this but can this cause a misfire?
Cuv15
Feb 17, 2019 01:10 PM
TDIGREEN1
Jan 16, 2016 12:42 PM
2001rx
RX - 1st Gen (1999-2003)
Jan 16, 2015 09:03 PM
94LexES
Apr 13, 2013 06:16 PM
FrankT
Feb 11, 2009 11:13 AM
