electric fan question
Old 10-27-07, 09:54 AM
SC3001
SC3001's Avatar
Default electric fan question
I bought the dual flex fans for my 300. I don't want to hook them up to ignition and have it run all the time while the key is on. I'm going to wire in a temp. switch in the thermostat housing (just drill and tap and run relay). My prob. is I don't know what degree switch to buy. I think the stock thermostat is a 180, if anyone has done this and maybe has part no. to the switch, please share this info. I've done numerous serches and it seems everyone is just wiring them direct, which is out of the question. Let me know what you think!
Old 10-27-07, 10:06 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
moved engine question to engine forum.
Old 10-27-07, 05:18 PM
rykwebb
rykwebb's Avatar
I have two 12" electric fans sitting in my room right now for this same reason. Don't know how to run the temp relay! I know it would be easier to have it running the whole time, but I'd rather them pull on at around 180-200 somewhere.
I can't help you anymore than you have been already. I'll talk to a few of my buddies here and see if we can come up with anything.
Old 10-28-07, 04:43 AM
SC3001
SC3001's Avatar
Yeah let me know, I guess everyone has it hooked up on 12v ignition or they would respond, I don't know..
Old 10-28-07, 08:32 AM
audi2nr
audi2nr's Avatar
http://www.customcarscentral.com/hks...all-makes.html
hks fan controller
Old 10-28-07, 09:30 AM
rykwebb
rykwebb's Avatar
ex-pen-sive. But definite thanks for the site, now I have to figure out how to make one those.
Old 10-29-07, 03:05 PM
Gunnar
Gunnar's Avatar
Flex-a-Lite has one that goes through the radiator and triggers the fans for pretty cheap.
Old 10-29-07, 04:56 PM
tavarish
tavarish's Avatar
On my ford probe fans, they have a high and low setting. I put the low on a relay and ran it to a 12v ignition source, so they run whenever the car is on, and they don't take too much amperage, but if the car runs hot, I wired the high setting to my factory valet switch in the driver's compartment. This would be used mainly after track passes.
Old 10-29-07, 06:18 PM
ihiryu
ihiryu's Avatar
probe fans on the SC?? I know we 240 guys use the ford taurus fans on our cars for cheap electric fans. How are the probe fans working out, is it single or duals??
Old 10-29-07, 08:48 PM
Harbinger
Harbinger's Avatar
Here's what turbochris did, and what I was planning to do verbatim, when I have a day free to go to the salvage yard.
https://www.clublexus.com/forums/sho...ght=stanza+fan
Old 10-29-07, 09:30 PM
ihiryu
ihiryu's Avatar
wow looks pretty promising. But it doesn't talk about how to remove the hydro fan assembly
Mvinhie
10-08-13 08:55 AM
imDementeD
SC- 1st Gen (1992-2000)
34
06-01-11 12:38 PM
FondoMynob
08-20-10 07:52 PM
MDGS4
02-25-09 12:06 PM
Quick Reply: electric fan question
