Electric Fan Conversion
Old Aug 20, 2010 | 11:20 AM
FondoMynob's Avatar
FondoMynob
Default Electric Fan Conversion
MY SC300 was converted over to electric fans from the previous owner. Right now it is hard wired to the ignition so the fans run the whole time the car is on. Is this how most people do it when converting or do they install a temp switch to power on the fans when the car gets up to temp.
I just dont want to have to replace my fans every year because they burnt out or something. Any input would be appreciated. Thank you.
Old Aug 20, 2010 | 11:33 AM
twizted's Avatar
twizted
Usually you would have a temp switch plus and ignition cut of. Off because if you just ran a temp switch it would still run after the car was off till the temp of the coolant came down....
Old Aug 20, 2010 | 11:36 AM
BenStoked's Avatar
BenStoked
CL Folding 1,000,000
yes, they can be hard wired, or temp controlled.
it is highly recommended by most to have a relay and fuse in case something happens (god forbid).
if/when i go this route, I will be using a temp controlled setup. they are cheap, and usually easy to install.
Old Aug 20, 2010 | 11:39 AM
FondoMynob's Avatar
FondoMynob
anybody got a DIY or a list of parts i would need to complete this?
Old Aug 20, 2010 | 12:05 PM
BenStoked's Avatar
BenStoked
you want something like this:
http://www.summitracing.com/parts/SUM-890015/
generic install instructions:
http://static.summitracing.com/globa...20890016-a.pdf
not sure where to install the thermoswitch, therostat housing, maybe?
Old Aug 20, 2010 | 07:37 PM
SC300_704's Avatar
SC300_704
i just run a switch to the fans.
Old Aug 20, 2010 | 07:52 PM
romycha1's Avatar
romycha1
^^ So how do you when to turn them on?
kelvin13
Aug 14, 2014 04:50 AM
Dvinhie
Feb 17, 2014 01:02 AM
Glock20C
GS - 1st Gen (1993-1997)
Mar 3, 2013 11:43 AM
ozzie
Nov 18, 2008 05:47 PM
