compression #'s
Old May 1, 2007 | 12:48 AM
tuninghaus's Avatar
tuninghaus
Default compression #'s
anyone know what #'s we should see in a compression for the SC300 (pre-vvti- 92-97) "healthy" motor?
i think the non vvti are 9.5 or 10.0:1 compression ratio? and the vvti is 10.5:1?
thanks
Old May 1, 2007 | 12:52 AM
booja's Avatar
booja
thanks
"healthy compression" when you run tests and compression ratios are are not the same...
when you run a test youre not gonna see 10:1, youre gonna get a number in psi like 195
i dont know what healthy numbers are for 2j is but it should all be in close range...
if thats what youre asking...
Old May 1, 2007 | 05:36 AM
blaznsc4's Avatar
blaznsc4
when doing a compression test make sure that all cylinders are no more than 15psi apart from each other.
Old May 1, 2007 | 08:05 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
use the engine forum.
Old May 2, 2007 | 01:12 AM
tuninghaus's Avatar
tuninghaus
lol yes i know the difference between compression #'s and compression RATIO. sorry, i was asking two questions, what are the compression #'s on normal healthy 2jz-ge's (pre 98's) AND what is the compression RATIO on them.
yes i did do a search, don't know but i didn't see many topics that answered my questions.
Old May 2, 2007 | 09:28 AM
SiennaII's's Avatar
SiennaII's
compression specs are 178psi or more, 142psi minimum with a difference of no more than 14psi and that's from Toyota's TIS system.
Old May 2, 2007 | 02:36 PM
tuninghaus's Avatar
tuninghaus
thank you!!! that is on the pre-98 SC300's right?
i know my supra had around 140-150psi compression 8.5:1 but it ran very strong and put down probably 750-800whp still.
a fellow lexus owner quoted to be over 200psi. i found that kind of strange and oddly high.. even for higher compression motors like ours. glad that it's in the 178-180 range...
my first three cyl read exactly that, 180's and the last three read like 200-210! lol
Old May 2, 2007 | 05:52 PM
blaznsc4's Avatar
blaznsc4
i did a compression test on my 1j and it was 170 across the boards.
Old May 2, 2007 | 11:05 PM
tuninghaus's Avatar
tuninghaus
that's good stuff man! but i think 1jz's are 8.5:1 compression as well? the 2jz-GE being a 10:1 motor might (should) read higher compression #'s... ?
Old May 3, 2007 | 12:42 AM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
im rockin a great 172 all teh way around except for the 6th cylinder 165 barly made it
Old May 3, 2007 | 06:18 PM
SiennaII's's Avatar
SiennaII's
Yeah, specs were for a 92 SC, non VVT-i
Bankswood
Apr 12, 2017 03:37 PM
Jacj3
Jun 8, 2010 04:01 PM
Dx3
Sep 11, 2009 09:13 PM
Boost'n
Apr 10, 2002 12:57 PM
