SC400's Cold Air, Ignition, and Exhaust
Old 07-27-05, 03:00 PM
stevechumo
stevechumo's Avatar
Default SC400's Cold Air, Ignition, and Exhaust
I'm just thinking about how much horsepower I will gain for doing these upgrades on a 1995 SC400.
1) A cold air system that I plan to cut a hole under the stock air box position and run a full custom intake pipe and its filter down underneat. I might use the Bypass valve by AEM, which eliminate the water to be sucked in the engine. I believe it'll make more hp than the short ram or stock air box. How much hp will I gain?
2) 2 MSD 6AL ignition boxes with external coils that give more sparks. How much hp will I gain?
3) A full exhaust system including the 2 hi-flow cat-converters in the upper part, with no big cat in the middle like stock, and 2 resonators near the rear mufflers. I will still use the stock headers since I don't want to haul the engine out. How much hp will I gain?
Any info. is greatly appreciated.
Old 07-28-05, 02:03 PM
JTJerryls400
JTJerryls400's Avatar
try piggy back
with ONLY tune it with piggy (STOCK car) I gain 17 rwhp (that is 20 crank HP) and 15 rwlbs (about 18 lbs on crank) in wide RPMs range.
car run much faster and stronger than before
I think that afrer headers+ full exhaust and with tune it with that piggy back 50 hp gain is easyly possible.
You MUST have possibility changing ECU inputs and outputs to gain max from mechanic changes you will do. Without you do not even unleas half it can do .
there is my piggy back
perhaps it will be avaible...
https://www.clublexus.com/forums/sho...d.php?t=172232
Old 07-28-05, 04:33 PM
Dx3
Dx3's Avatar
1) A cold air system that I plan to cut a hole under the stock air box position and run a full custom intake pipe and its filter down underneat. I might use the Bypass valve by AEM, which eliminate the water to be sucked in the engine. I believe it'll make more hp than the short ram or stock air box. How much hp will I gain? 8-10hp ( wheels)
2) 2 MSD 6AL ignition boxes with external coils that give more sparks. How much hp will I gain? 2-5hp ( wheels)
3) A full exhaust system including the 2 hi-flow cat-converters in the upper part, with no big cat in the middle like stock, and 2 resonators near the rear mufflers. I will still use the stock headers since I don't want to haul the engine out. How much hp will I gain? 10-15 ( wheels)
Those are being positive numbers.
Jonny
Old 07-28-05, 07:16 PM
stevechumo
stevechumo's Avatar
Originally Posted by JTJerryls400
try piggy back
How much does that piggy back computer cost? Who sells it? I've use Apexi SAFC-II before for a turbo system but I don't think the Apexi can do such thing as yours. I also believe your piggy back computer is almost like a full function computer which can increase or retard timing, too. However, your tuning is awesome!
Old 07-29-05, 06:45 AM
JTJerryls400
look there
https://www.clublexus.com/forums/sho...03#post1421603
Durvelle27
03-22-15 01:38 PM
Houses1
11-26-14 08:20 AM
1stgenGSb
GS - 1st Gen (1993-1997)
10-01-06 05:40 PM
cliffud
11-05-05 04:11 PM
ot180
11-30-04 09:54 PM
Quick Reply: SC400's Cold Air, Ignition, and Exhaust
