Dent and Paint Damage on Rear Door
Hi All, the underground parking in downtown is tight that I ended up scratching my right rear door against the concrete column. See the photos below.
Any idea on how much it might cost to repair it? I am located in Vancouver, Canada and is planning to get estimate from autobody shops Monday morning. Hopefully, it does not involve replacing the door for this size and complexity of damage!
Your response is much appreciated!!
Since there is no response, I will ask the following questions?
What kind of repair would be done to fix this?
What would be the cost to do something like this in the States?
Looking foward to hearing from you all.
Thanks!
Thanks!
Looks like you hit the pole and kept going, which probably wasn't the best idea in minimizing damage. That might be quite an expensive repair...for sure the black trims need to be replaced due to severe gouges. It looks like the dents are on the crease and the edge, which may be difficult for bodyshops to straighten out...so they may suggest new panel. Not sure how deep the gouged are on the rear bumper, but some bodyshops may suggest replacement. When they paint, they will need to blend between multiple panels to match...more difficult if you have the pearl effect white.
If you take it to a reputable bodyshop, it'll probably be at least $1K. Just take it to a reputable shop for an estimate.
lexinx (09-25-17)
If you have good insurance, they will probably allow the repairer to replace both pieces of black trim, and re-skin the door. Don't know what the trims cost, but could easily be a few thousand all up. A dodgy repairer will just bog the door and ignore the trims but even this would cost several hundred.
lexinx (09-25-17)
Hi dchar and fixadent:
Thank you for your reply! I applied for insurance claim online. I visited one of the autobody shops. The estimated cost is $3,000 to do the following:
Total parts is about $700
Total labour is about $2,000 with 27.5 hours
I haven't decided anything yet as I am waiting for claim approval from insurance. Seems a bit excessive to me. Your thoughts?
- Replace black trims
- Fix the metal sheet on rear right door
- Repaint the whole right side of the car (front door, rear door, quarter and rocker panel) using three stage colour
Price sounds about right...good repairs aren't cheap. Hopefully you picked a reputable shop. Sometimes it's best to ask your dealer who they use. Whoever they use needs to be good when repairing new cars that are damaged upon delivery.
Glashub
07-21-15 02:21 PM
