NX - 2nd Gen (2022-current)
When I lock car by touching handle I get multiple beeps
Old Mar 21, 2023 | 09:09 AM
LiBeRtAs's Avatar
LiBeRtAs
Originally Posted by Gbobst
If you have the digital key option, it comes with a credit card key, and is in the manual. What you are describing is a key in the vehicle signal. It will not allow you to lock the vehicle by touching the door handle slits. If your manual is in the vehicle, check that. Also like the post before, Digital key has range settings and can be found in the app in the digital key. You can lower the frequency. And if you are leaving your phone in the vehicle and have digital key, the vehicle will sense a key in the vehicle and give you the beeps.
The rear seat reminder will also beep after you lock the doors if on, to make you look back so as not to leave an important passenger in there!
Hope this helps!
I have the option to use the digital key but I don’t have it set up because it drains the battery on the phone and it was not working so I don’t use it and I do use the credit card key. When it does the multiple beeps there is no key left in the car.
You say credit card key is in the manual, are you saying there is a section in the manual about the credit card key? If the credit card key is in my pocket when I get out of the car why would it be doing multiple beeps?
It does lock the door and folds the mirrors in even when it does the multiple beeps.
That reminds me, I use the credit card key exclusively and I have the app on my phone and I do not have the digital key downloadef per my other comments; is there a way to use the credit card key or the app to make the horn honk because you can’t find your car, the emergency thing? I just found hazards, horn and buzzer buttons, not sure which is which I guess I will experiment.
Old Mar 21, 2023 | 09:27 AM
Gbobst's Avatar
Gbobst
I was thinking you may have inadvertently left the credit card key in the vehicle in the manual. Obviously if the mirrors are folding upon locking via the handle then there is no key in there. Keep in mind, that you CAN lock a key in the vehicle using the key FOB buttons, and if you are doing it that way, there may still be a key in there somewhere.
So the beeps probably are for the rear seat reminder. When you turn it off in the main menu at settings> vehicle customize> utility> rear seat reminder, it will do so for that PROFILE loaded only. If you have multiple profiles, or are in Guest Mode, then you have to turn it off again for those profiles and the guest mode, individually. I know, ridiculous right? I don't engineer it, just show how it works.
Also, in the app there is a part in profile> account> notifications> rear seat reminder that you turn off also.
Old Mar 21, 2023 | 09:43 AM
LiBeRtAs's Avatar
LiBeRtAs
So you did mean there might be an actual physical credit card key, a second one, in the manual, OK I will check in a little while when I go out there, I will also check the other profiles for the backseat reminder, good point thanks.
I doubt there are two credit card keys and I know you mean the only one might be in the manual that I did not know about. Must be the rear seat reminder, which has caused more trouble for so many people I think and there’s too many places you have to turn it on or off and different profiles etc.
Old Mar 21, 2023 | 09:45 AM
LilyTiger's Avatar
LilyTiger
One way to make sure: when you lock the door and get the beeps you’re describing, peek in and take a look at the instrument cluster display. It usually says on there what’s going on.
PandaGS300
Oct 5, 2016 03:31 PM
jord533
Mar 5, 2014 03:25 PM
Aristo722
Feb 16, 2014 09:44 AM
frotiss
IS F (2008-2014)
Dec 30, 2012 07:59 PM
Blueshark
15
Apr 23, 2010 12:53 PM
