NX - 2nd Gen (2022-current)
Run flat tires issue
Old Dec 4, 2022 | 02:22 PM
chumpchang's Avatar
chumpchang
If you look at Tire Rack's website, they will state the conditions on which a RFT can be repaired, but even then as others have stated, there might not be someone willing to go through the trouble of repairing it.
https://www.tirerack.com/tires/tiret...jsp?techid=226
Old Dec 4, 2022 | 04:05 PM
Lex2000TL's Avatar
Lex2000TL
You may get lucky. Since tire does not loose air, the nail, perhaps did not puncture through.
Old Dec 4, 2022 | 04:44 PM
chumpchang's Avatar
chumpchang
I do not rely on luck when it comes to the only thing that connects my car to the road.
Old Dec 6, 2022 | 06:21 PM
SalemNx350's Avatar
SalemNx350
Thanks everyone! Replaced the tire with a new one. It’s not cheap which makes consider buying the lexus hazard protection plan. I know there is another thread for this topic but still can’t make a decision if it would worth it!
Old Dec 6, 2022 | 06:35 PM
blueless's Avatar
blueless
Question questions, i have them
Originally Posted by SalemNx350
Here is the nail, I don’t think it can be repaired! The interesting thing is that it’s not leaking or causing any issues at all so far except a rattling noise (sounds exactly like having an actual flat tire). I’m not even sure if the nail is causing the sound or not
  • Did the screw penetrate the tire? I hope you got to look at the old tire after it was unmounted. (Ha, I just typed "screw," "penetrate," and "mount" in quick succession.)
  • Did the noise go away after you replaced the tire?
Some mom and pop garages are willing to repair tires where big-chain shops won't. It's a little bit risky, but can potentially save much money.
Old Dec 6, 2022 | 07:01 PM
SalemNx350's Avatar
SalemNx350
Originally Posted by blueless
  • Did the screw penetrate the tire? I hope you got to look at the old tire after it was unmounted. (Ha, I just typed "screw," "penetrate," and "mount" in quick succession. it did penetrate the tire, it already started leaking on my way to change it
  • Did the noise go away after you replaced the tire. it did!
i called few ones, no one was willing to touch it, i eventually replaced it at a Toyota dealer because it was closest to me than Lexus
Husam131
LS - 5th Gen (2018-present)
Jun 19, 2022 08:47 AM
Karter01
Nov 8, 2009 06:37 PM
LIMS407
Aug 17, 2009 04:51 PM
MJK
Dec 3, 2007 09:49 PM
IsraelRX
Sep 19, 2005 09:29 AM
