NX - 2nd Gen (2022-current)
Wireless Charging
Old Apr 14, 2023 | 09:22 AM
  #91
Smooth2o's Avatar
Smooth2o
Originally Posted by azieba
To find the ring see the amazon link in my post above. While Batty used it, I actually did not. My 2023 came with the updated wireless charger and it works great without the ring on my Iphone14 coupled with the official Apple Leather Magsafe case.
Did you find that due to the hump the iPhone 14 moved around during driving and that stopped the charging or did they change the pad so it sticks more? I am getting a ‘23 at the end of the month so interested. I understand that provided you have MagSafe charging, the ring only keeps the phone from moving around but the hump won’t allow flat contact and therefore not a good charge either.
Old Oct 2, 2023 | 08:09 PM
  #92
Maunglin's Avatar
Maunglin
1st Gear
Originally Posted by Lexus22563
Hopefully Lexus will issue a recall and fix this charging tray.
I just find out 2024 nx350 wireless charger working fine with case no problem. My 2022 nx350 did not charge with iphone13 pro with same case. I think they change the new charger.
Old Oct 6, 2023 | 08:50 AM
  #93
Granged's Avatar
Granged
Just breaking in my new 2024 white with palomino NX350h. A beautiful piece of Canadian workmanship. Qi charging pad is very unreliable which is very un-Lexus-like. Hope they are working on a solution to this embarrassing flaw.
Old Oct 7, 2023 | 10:36 PM
  #94
Pandaroo's Avatar
Pandaroo
2024 350h with s23 ultra in a mous case with magsafe.
Wireless charger hasn't skipped a beat. Maybe the car has the upgraded charger or the case sits flat on the charging pad
Old Oct 8, 2023 | 05:35 AM
  #95
ctripps2k's Avatar
ctripps2k
nope. They don’t even acknowledge it as a problem.
Old Oct 8, 2023 | 07:16 AM
  #96
Dblxx's Avatar
Dblxx
Originally Posted by Batty
So this is what I did and it works. I have an iPhone 12 Pro. The wet streaks are from the alcohol I had just wiped everything down with. The phone sticks well to the ring (I have a MagCase on it). Charging is no slower than it was without the ring and it keeps the phone from sliding around and off the charge plate.
So you bought just the Mag ring so it's always positioned properly on the charging pad? That's brilliant....
Old Oct 8, 2023 | 07:18 AM
  #97
Dblxx's Avatar
Dblxx
So something like this....
Amazon Amazon
Old Oct 8, 2023 | 05:37 PM
  #98
buhdeh's Avatar
buhdeh
I don't think the mag ring is gonna make a difference on these newer phones like the 14 Pro and 15 Pro that have massive camera bumps.
Old Oct 10, 2023 | 09:14 AM
  #99
jgrnt1's Avatar
jgrnt1
22 NX 350h, iPhone 13 Pro Max in a leather MagSafe case. I've given up on the NX's wireless charging, even after the dealership replaced the tray with the updated part. It was still intermittent. I also had problems with overheating when it was charging. I've had this issue in several makes of rental cars as well. If I wirelessly charge the phone and use wireless CarPlay, the phone sometimes overheats and stops CarPlay until it cools down. It's rather unnerving when driving in an unfamiliar city and navigation suddenly disappears from the screen.
I now use only wired CarPlay when in rental cars. For my NX, I got a MagSafe mount powered with the USB-C port. Interestingly, I use wireless CarPlay with this and it never overheats. This may be due to more stable wireless charging (no camera bump gap).
Old Oct 10, 2023 | 09:24 AM
  #100
Dkaplan's Avatar
Dkaplan
This works perfectly!
Old Oct 10, 2023 | 09:25 AM
  #101
Dblxx's Avatar
Dblxx
Well, if the ring is raised then it should compensate for the cameras thickness. With wireless charging a "thick ring" should do the trick and still be able to get the juice into the phone.
Also, the ring should hold it in the perfect spot for charging.
For me - my phone holds charges for days - AND - if using CarPlay... the phone uses VERY little juice because the car screen is pushing out what typically costs the phone to drain most quickly. (the screen)
Old Oct 10, 2023 | 09:27 AM
  #102
ctripps2k's Avatar
ctripps2k
depending on where you live, i wouldn’t leave that out in the open. Bright white gonna attract people.
Old Oct 10, 2023 | 09:28 AM
  #103
Dblxx's Avatar
Dblxx
I use similar - just a flat pad versus a ring. Works perfectly in my wifes base NX.
Old Oct 10, 2023 | 10:50 AM
  #104
jgrnt1's Avatar
jgrnt1
My MagSafe solution:
Old Oct 10, 2023 | 11:59 AM
  #105
lsft's Avatar
lsft
I have verified that the 15 pro max with a case does not charge. I will try it without and see soon.
