NX - 2nd Gen (2022-current)
Is the panorama/moonroof laminated glass?
Old Feb 27, 2022 | 05:23 PM
gcskoor's Avatar
gcskoor
Default Is the panorama/moonroof laminated glass?
Can someone please check the glass imprint (and maybe a picture too) to see if Lexus Is using laminated or tempered glass in the panorama and moonroof glass? Laminate should stops UV (usually in the 90+) - much more than tempted glass. And consider safer than tempered glass. I can find Lexus spec on the windshield and front side window that they are using acoustic glass, which is laminated, but nothing on the pan/moon specs wise.
Thanks
Old Feb 28, 2022 | 12:05 AM
ttaylor121's Avatar
ttaylor121
Thanks
The lamsafe glass is only on the windshield, and front door windows, all others are tempered, including the panoramic roof panels
These are the marking from the panoramic roof panels on mine..
Edit: the pano roof has a powered shade, 100 blackout..
Old Feb 28, 2022 | 02:02 AM
gcskoor's Avatar
gcskoor
Thanks for the pics, but darn it. I was hoping for an upgrade this year to a laminate- probably mostly weight restriction and perhaps cost keeps this from happening.
A couple months ago, the dealer had a few already sold NXs. I could not drive, of course, but I did grab my simple UV tester card to to check the side windows and roof panels. This was just one thing I was looking, but it did seem to indicate the UV was reduced pretty effectively on the side glass and roof panes in just the few seconds that I tested. I did not test rear window or rear side windows.
I had just assumed it was a laminate glass with good UV rejection by my simple UV test. But I realized later that it was probably just a coating.
It does seem AGC has UV coatings on tempered glass (and also IR rejection), that would make perfect sense of Lexus to be using for the roof panels. It does seem Lexus has been using UV glass for sometime. Not sure about IR. One of the reason to get a NX over a Rav4- pretty sure it does not have UV glass. It the NX has IR rejection, that will be excellent. My 2017 Touring CRV has no UV rejection on side/roof panels glass.
AGC's trade name name for their UV glass is UV Verre Premium Privashield. I bet the UVS symbol indicates this is the temperlite with UV protection.
https://www.glassonweb.com/news/worl...-privashieldtm
https://www.agc-automotive.com/en/ou...ss-temperlite/
Sep 29, 2018 08:33 PM
Johnhav430
Sep 6, 2017 11:40 AM
vstyle444
Mar 3, 2016 09:02 PM
zbskii
CT 200h Model (2011-2017)
24
Oct 24, 2011 09:55 AM
sleepybobcat
RX - 1st Gen (1999-2003)
Feb 3, 2002 06:45 AM
