NX - 2nd Gen (2022-current)
Battery for keycard
Old Dec 30, 2025 | 05:33 AM
TraderAlex's Avatar
TraderAlex
5th Gear
Default Battery for keycard
My NX is new since end July 2025.
And it seems that the battery in the card is already dead. The service department told me that the battery was only about three months, but the cost of the battery is 20 something dollars, but that would not normally be covered under warranty or under the service contract I bought. But they would do it for me this time as a favor….. because the batteries are consumable item. Well, so is everything else under the service but that’s another story. So if you go by what they say, but a three month service life, that means an owner’s out-of-pocket cost would be about $100 a year to service the card and keep it working that. Does that make any sense? What is the battery model? Is this something that one can buy themselves at CVS or Home Depot?
Old Dec 30, 2025 | 05:41 AM
Freds430's Avatar
Freds430
CR2412
We both use the wallet card in our NX and RX and never had one go dead. I change them once a year. $6 on Amazon.
Old Dec 30, 2025 | 06:11 AM
lsft's Avatar
lsft
I bought 4 batteries for $22 CAD from Amazon. It typically last about one year. But this depends on your usage.
Old Dec 30, 2025 | 09:32 AM
TheCDN's Avatar
TheCDN
Just as an FYI, wear and tear items are typically not covered unless explicitly stated in a maintenance plan. So that's typically things like wiper blades, washer fluid, coolant, brake fluid, brake pads, rotors, and key fob batteries too.
Old Dec 31, 2025 | 06:31 AM
LDV's Avatar
LDV
4th Gear
Default Cr2412 3v
My ‘25 NX450 smart key card lasted 10months with daily usage. CR2412 3V - $26 for Panasonic 5 pk - matched original. Easy to replace.
Old Dec 31, 2025 | 09:55 AM
TheCDN's Avatar
TheCDN
On average I would say about 10-12 months of life for all batteries in the fobs or cards that see regular use. I've gone through 2 on my '22. I don't drive that much and when I'm not using the car I put my primary fob into a faraday pouch so it goes to sleep and doesn't consume the battery. With my last recent replacement I put a note into my phone to record the date so I can review when it goes again, how long it's lasting. My other fob and my key card sit in a separate faraday pouch and so far they're both still on the original batteries.
Old Dec 31, 2025 | 02:11 PM
Droid13's Avatar
Droid13
The manual says the key card battery is good for "about 1 year" and the regular fob battery is good for "1 to 2 years". I got almost 18 mths out of my key card battery and my first fob battery lasted almost 2 years. My second fob (which is 8 mths younger than my first fob, due to the key fob shortage) is still on the original battery so a little more than 2 yrs so far, although it rarely gets used. I just get whatever Amazon battery replacement looks best for cheap, they might not last quite as long but they are so cheap and so easy to replace I won't mind if I have to do them a bit more frequently.
Old Jan 1, 2026 | 05:45 PM
oreon333's Avatar
oreon333
If you want a good battery that lasts long get the ones that are from Swiss or Japan.
Old Jan 1, 2026 | 11:40 PM
hintonwood's Avatar
hintonwood
I second this. I repair watches and my go to supplier for quality batteries is Renata - a Swiss company.
Old Jan 2, 2026 | 01:32 PM
gamma742's Avatar
gamma742
Has anyone tried to lay the cardkey on the button to start the car when the battery was dead or removed? I'm wondering if it will allow you to start the car the same as the FOB does when dead.
I would try this myself but I don't own a cardkey as I bought our NX as a CPO with just 2 FOBs.
Old Jan 5, 2026 | 06:50 AM
Freds430's Avatar
Freds430
The wallet card does work just like the key fob if the wallet card battery is dead by holding it right against the start button with the brake pedal down. Can experiment by taking out the battery to the wallet card.
Old Jan 5, 2026 | 07:02 AM
lsft's Avatar
lsft
I can confirm that it works like a keyfob. When the battery is low or dead you can put it against the start button to start the car. Use the key to open the door manual. But the battery of the key card should last 1 year if you have good quality batteries.
Old Jan 5, 2026 | 11:23 AM
gamma742's Avatar
gamma742
Thanks Guys, "Likes" to you both!
Old Jan 21, 2026 | 03:19 PM
Flvike's Avatar
Flvike
10th Gear
I just replaced mine. CR2412 Panasonic is what I used. Works fine. I believe it was $8 or $9.
sajack
LS - 5th Gen (2018-present)
17
Apr 29, 2026 08:38 AM
BigMF
Maintenance
May 8, 2020 10:55 AM
stanatl
Dec 12, 2014 10:15 AM
is250gurl
Jun 29, 2009 06:18 PM
GS430 GUY
Mar 1, 2001 06:12 AM
