Battery gotcha finally got me.
IMPORTANT: CHARGE IMMEDIATELY AFTER PURCHASE, AFTER EACH USE AND EVERY 30 DAYS, TO KEEP THE JUMP STARTER’S INTERNAL BATTERY FULLY
CHARGED AND PROLONG BATTERY LIFE.
5.1 CHECKING THE LEVEL OF THE INTERNAL BATTERY
Press the Light/USB Power button on the front of the unit. The LEDs will indicate the current charge level as follows:
● ● ● ● 100% charged
● ● ● 75% charged
● ● 50% charged
● 25% charged
Charge the internal battery if the LEDs indicate less than 75%.
5. Charge the unit as soon as possible after use.
7.7 Charge at least once every month, if not in frequent use, to prevent over-discharge."
I will check it every couple of months to make sure is 75% charged. The other jump starers that I have hold the charge more than 6 mo. I have never had this brand so I will check it sooner.
Your link is off on the timing, it should be more like this:
https://youtu.be/c4hpQGxq4iY?t=127
Lock, then quickly double tap Lock.
You'll hear the beep from the locking, and then 2 more beeps.
I think the 2 more beeps indicate that it's in battery guardian mode.
