NX - 2nd Gen (2022-current)
TPMS sensor issue
Old Aug 17, 2025 | 09:27 AM
Mrnovanova's Avatar
Mrnovanova
Default TPMS sensor issue
Good to know: I have a set of 19 inch rims and tires with aftermarket TPMS sensors.
Yesterday, I was driving on a gravel road when my TPMS warning light in the dash turned on. I also have a message telling me to visit a dealership.
The Lexus app shows the status as normal with all tires having adequate pressure. I verified them by hand and everything is normal.
Has anyone experienced this before? Any advice as to what I could do to troubleshoot the issue?
Thanks in advance.
Old Aug 17, 2025 | 10:59 AM
TheCDN's Avatar
TheCDN
I would start by questioning your aftermarket tpms sensors. The tpms used on Lexus NX is a newer iteration in design. You don't mention how long you've had the tpms and your 19" rims installed and functioning fine. To start tpms are battery operated, each one has a battery in them to send out their signal which is a very specific frequency and must align with the vehicle's frequency that it's looking for or things don't talk to each other well. The message that's telling you to visit he dealer may be because the battery in one may be low, or maybe the car can't 'see' the tpms signal well.
I would start by going back to the shop you used to do install and maybe they can diagnose the problem with a tpms reader tool that's used to set them up correctly. They should also be competent in knowing what frequency the tpms are required to have for your vehicle, these are very vehicle specific items, not all will work.
Old Aug 17, 2025 | 11:41 AM
Mrnovanova's Avatar
Mrnovanova
I've had them for 3 years with mo issues. Can't go back to the installer as I moved across the country. Thank you for your reply. I gives me a good place to start.
Old Aug 18, 2025 | 05:40 AM
Droid13's Avatar
Droid13
I wouldn't use the Lexus App as the definitive status of tire pressure since its not a real time display, use the infotainment system tire pressure display for that. If your tire pressures are indeed proper, there really is two main possibilities, a sensor is malfunctioning, or the receiver in the car is. If its the receiver in the car, it would be a warranty item, but the trouble you may potentially face, the dealer may be grumpy enough to dismiss it without reverting back to OEM sensors.
Old Aug 18, 2025 | 06:40 AM
Mrnovanova's Avatar
Mrnovanova
You're absolutely right about the App. I noticed that the values I see are from August 12th and it doesn't update when I refresh so it looks like the sensores are no longer communicating with the car. Thanks for the advice.
Old Aug 19, 2025 | 02:53 PM
TheCDN's Avatar
TheCDN
Yes the app will only show you your last updated info for pressure BEFORE you shut it off. To save parasitic losses on the 12 volt battery the car doesn't communicate with the tpms when it's not running.
Old Sep 7, 2025 | 12:16 PM
Mrnovanova's Avatar
Mrnovanova
Default *update*
So I ended up buying a set of TPMS sensors off of Aliexpress for $34 CAD. Went to a Fountain Tire to have them installed for $100. Did the register a new set thing, drove for about 15 minutes on the highway and it worked. So I paid under $150 total. Lexus wanted $100 to scan and then $125 per sensor. So between $225 and $600, but I'm sure it's the latter because they would have asked me to get the hole set for $500 and they maybe would have charged for the install.
If anyone is in a similar situation and would like a link to those sensors, let me know.😊
Lx3232
Jan 9, 2026 07:36 PM
wayman28
Aug 18, 2025 12:51 PM
sthpawil
15
Jun 4, 2025 07:30 PM
bagofchips
RX - 3rd Gen (2010-2015)
Oct 11, 2023 10:00 PM
Myrix
Wheels, Tires & Brakes Forum
Jul 5, 2016 08:59 PM
