Tpms
Old Jul 6, 2025 | 08:31 PM
wayman28's Avatar
wayman28
Default Tpms
Hi all, I've got a 2009 LS SWB and I got a TPMS light on the dash. I took it to my local tire place and they identified the driver side rear TPMS sensor as not reading. They replaced the TPMS and cleared the codes. However I drove the car for two days and that one TPMS stays in "Checking" status. The other four sensors showed a pressure reading on the dash. The TPMS warning light eventually came back on. I hooked up my Autel scanner and was able to get a pressure reading from all five TPMS sensors. But when I drive the car and watch the live data from the Autel that one TPMS doesn't show a reading whole the other four do. I'm guessing the TPMS module/receiver in the car is faulty but I'm not sure. Does anyone have any advice? Thanks in advance.
Old Jul 7, 2025 | 12:49 AM
Dean2's Avatar
Dean2
If I paid to have it fixed I would take it back and get them to fix it right. Why should ypu clean up their mess.
Old Jul 7, 2025 | 04:36 AM
jmcraney's Avatar
jmcraney
Good advice from Dean2. ‘’Checking” is caused by a non-reporting sensor. Situations like yours are usually the result of a failure to correctly register a new sensor or a wrong sensor part number.
Old Jul 7, 2025 | 07:15 AM
dmanb2b's Avatar
dmanb2b
^^^ this...sensor needs to be programed/registered to the ECU
Old Jul 7, 2025 | 12:49 PM
wayman28's Avatar
wayman28
Thanks everyone. I definitely planned on taking it back to the shop but I wanted to get educated beforehand. I took it back and they performed a relearn procedure which fixed it. So you were right. Thanks again.
Old Aug 17, 2025 | 11:19 AM
carbons's Avatar
carbons
5th Gear
Aftermarket TPMS can be hit or miss. Sometimes they’ll throw a warning even when pressure’s fine. I’d try pulling the negative battery cable for a few minutes to reset the system or do a TPMS relearn. If it keeps popping up, one of the sensors might just be starting to fail.
Old Aug 17, 2025 | 05:11 PM
Bovineplan's Avatar
Bovineplan
You can't relearn a new sensor that isn't programmed. The system detects the signal but the serial number isn't programmed to the system. If it was someplace like discount tire, they won't be able to program a new sensor.
Old Aug 17, 2025 | 05:22 PM
Dean2's Avatar
Dean2
The part about needing to have registered it in the first place is accurate, but the second part isn't, at least generally. Not sure about Discount but the vast majority of tire shops can register new TPMS to a Lexus, or any other vehicle
Old Aug 18, 2025 | 05:33 AM
texas008's Avatar
texas008
yes DT can program the sensor.
A new TPMS sensor is about $65 each installed at DT.
Old Aug 18, 2025 | 12:51 PM
lexo98's Avatar
lexo98
Relearn is when you input the sensor ID’s into the ECU. Programming is typically done on an aftermarket sensor so the it is in the correct mode for the ECU to communicate with it.
c0sty
NX - 1st Gen (2015-2021)
Feb 25, 2025 10:51 PM
toonkev667
Sep 12, 2024 01:44 PM
CoFo
Sep 20, 2023 01:44 PM
j1ffrey
Sep 8, 2022 01:08 AM
ACP84
Nov 7, 2019 10:29 AM
