Tire psi
I switched over to 20” sport wheels.
my question would be, does the Psi remain the same? Or should the 20” have more psi.
anyone out there with the original NX sport wheels I would be curious to know what the psi on the side of the inside of your dad reads.
thanks
thanks
Good Luck.
YMMV,
MidCow3
I know the ride is a bit harsher but since it's mostly highway driving and very few potholes/uneven surfaces that isn't a real concern.
I had the same thing happen with my previous car, an Audi A6. The service department had a chart from Audi which they used to set tire pressure and it did not match the manual spec.
Increasing the PSI reduces the rolling resistance by decreasing the the tire contact patch size. What does this actually mean:
(1) you traction is decreased. If you try to start fast you will spin your tires. This is more apparent in rain or other inclement conditions
(2) your stopping distance will significantly increase, Again, much more apparent in wet or inclement conditions.
(3) your tire wear and total miles per tire life will be decreased ( you are only riding on the center treads; the outer treads get very little wear). Newer tires have significantly longer tire life up to 80,000 miles, so you may erroneously thins increasing PSI is getting you longer tire life. But actually increasing PSI shortened your tire life.
(4) You handling will be deceased. To start with the NX is not a sports cat and does not handle like one. When you increase the PSI you handling is further reduced. This makes it more dangerous in traffic control and wreck avoidance.
(5) You have a much harder and uncomfortable ride.
(6) Finally a positive, , by increasing the PSI you will get 1 or 2 mpg higher.
Recommended PSI is best. But , please don't exceed maximum PSI. Even staying at maximum PSI you get many of the negatives mentions above. However, lower rolling resistance can increase your mpg by 1 or 2 mpg if that is your main goal.
Peace and roll on.
YMMV,
MidCow3
P.S. - on my 2023 Prius LE. I changed tires from OEM 195/60 R17 to 215/55 R17. It increased my rolling resistance and increased my patch size. Much better starting/stopping especially in wet and inclement weather. Increased the handling significantly. However, dropped my mpg down to about 48. But it was worth it. Yes, running tires at recommended PSI
After a short highway drive I brought them down to 42 psi. The door jam says 33 psi.
I think somebody messed up at the dealership.
I had my winter tire swap done mid April here in Niagara Falls Ontario. OE went on and pressure was set at 34 psi - which I'm ok with. That's when it was around 5-7 degrees Celsius (41-45 Fahrenheit). After a few weeks went by the air temps rose to around 16-18 C - 61- 64F, tires were reading 36-38 psi. That's a little too high for me, the ride is a little too stiff and harsh, I have 20" 50 series so a narrow side wall. Plus once you drive down the highway you'll get psi raised 2-3 due to heating up of tires. So I always put air in or out before driving it, when it's cool outside like early morning or early evening or at least when car has been in complete shade for a while. That way I get a good baseline temp and pressure that has had no influence on warmer midday temps. Like I mentioned earlier factory recommended 33+1 psi is where I set my tires giving me a slight improvement in rolling resistance.
BTW the manual mentions higher pressure be used when travelling over 160 kph or 100 mph for any length of time. That's because the sidewall flexing that occurs where the tire hits the road causes internal friction on the rubber and plys found in the tire sidewalls. This heats up the tire considerably and will shorten tire life if run at those speeds over a long period of the tires life. So no it's not going to cause a blow out or anything like that, but the tire's health or performance will be reduced slightly. Remember these tires are H (130 mph) or V (149mph) rated so they can handle constant high speeds with no problem.
