Tire psi
A couple brand new vehicles we bought over the years were delivered with 40-45 psi while the mnfr recommended psi was 32.
One dealer cracked me up, giving me their signed pre-delivery check-off list all checked off, but they sure missed checking the tire psi.
That 40 psi is more like a shipping air pressure.
Just had my 2022 350h in for the 30K mile service. I had new tires put on it the day before. When I picked up the car, the tires were all 36psi. I asked the service guy about it. He said their tire techs have a chart from Lexus they use to set the psi which does not match the 33 psi spec in the manual.
I had the same thing happen with my previous car, an Audi A6. The service department had a chart from Audi which they used to set tire pressure and it did not match the manual spec.
WTH does Lexus/Toyota engineers know? Everyone is their own rocket (tire) scientist. This debate about PSI can go forever and no matter what anyone says - everyone will be wrong. Why even bother reading owner’s manual? Just do whatever you want. No need to ask for satisfactory confirmation.
This is from the 2017 Audi A6 manual. I don't have the car anymore, but I believe the Maximum load settings matched the door sticker. The Normal load settings were the comfort settings.
My new 2025 NX350h is recommended at 33psi in the manual but they came at 37/38 from the dealer. Guess I should let a little out. No real surprise, my last Mercedes always came back from service 4-5 PSI above recommended.
Look at your driver's door sticker showing tire size and recommended pressure. Look at your tire pressure readout from the TPMS on centre stack once in a while. Buy a pressure gauge and air pump. Adjust accordingly.
Here endith the lesson!
Always follow the door jamb label for proper tire inflation. The 18" and 20" all call for 33psi "cold" The reason they typically come back from service with higher pressures is that the technicians use a temperature chart that basically equates to 1 psi for every 10 degrees F above "cold". But what is cold? I live in norther California and my typical winter low temp is around 35 to 40. So if I inflate to 33psi with the car sitting overnight, I should see 37 to 38psi with it 70-80 degrees outside. More pressure if I've been driving for a while and the tires get warmer. I've seen this on my GS, RX and NX. Hope this helps...
If you're seeing cold tire temps with 36 or 37 psi and don't adjust you're not going to get a 'perfect' ride, it'll be a little harsh, but will improve steering response as sidewall is a little stiffer and if left for 1,000's of miles you'll wear out your centre treads faster than treads at the edges too. In my climate you can typically set to 33 cold at every trip to get your oil changed which is usually 3-4 times a year and be done with it, no major drama, just take a boo at your tpms readings every once in a while to make sure everything is kosher.
