More comfy tires.
I just had the 35k service done and I got a nx350 loaner while they did that and replaced the rear dome light. The loaner along with other loaners I’ve received seem to have a better ride quality than my nx350h. The only difference I see is that I have the 20 inch wheels since. All the loaners have had the smaller wheels with thicker tires but still run flats. I’ll probably be due for tires in another 10k miles by the end of the year. Would it be possible to switch to slightly thicker tires? Would that mess with anything such as correct mpg or mph readings? Any recommendations on tires?
Michelin Cross Climate 2 or Pirelli Scorpion AS Plus 3. I have the CC’s and my wife the Pirelli. Both are excellent. The CC’s are quieter and the Pirelli have a slightly better road feel. Expect about 1 - 2 mpg drop with the CC’s.
Another non-run flat replacement to consider is the Yokohama XCV which is available in the 20" OEM size (235x50x20). It gets good reviews but I ended up going with the Pirelli's because I had them before on a previous vehicle and knew how well they performed. I was afraid of buyers remorse if I went with something else. Good Luck!
I get it, for most, it's put the tires in and don't worry about it. I work in real estate with builders and developers so I'm pretty much always driving by or into home construction sites and getting nails and other things in my tires. I also use the vehicle for road trips where one is more likely to have a blowout and not just something stuck in the tire, like a nail or whatever. I've already had one tire replaced on the current set because of this. I'm definitely more on the **** it mentality side of things but this is our main vehicle for all the things so I want to be a little extra careful and for the same reason, have the ride be as comfy as possible. Has the taller sidewall on the Pirelli Scorpion messed with your speedometer?
Below are estimates of the differences between the two tire sizes from a calculator you can find online.
Tire Size Calculator
Tire Size Comparison Calculator. Use this calculator to compare the sizes of two tires both numerically and visually.Result
Tire 1: 235/50R20Tire 2: 245/50R20
Difference:
Tire Height (Diameter) 29.3 in 743 mm, 29.6 in 753 mm: 1.35%
Sidewall Height 4.6 in 118 mm, 4.8 in 123 mm: 4.26%
Tire Width 9.3 in 235 mm, 9.6 in 245 mm: 4.26%
Tire Circumference 91.9 in 2,334 mm, 93.1 in 2,366 mm: 1.35%
Revolutions per Mile 689.5, 680.3: 1.33%. Revolutions per Kilometer 428.4 422.7 1.33%
Speedometer Difference: Tire 1 (mph or km/h): 20 40 60 80 100 120. Tire 2 (mph or km/h): 20.3 40.5 60.8 81.1 101.3 121.6
Citylights
Dec 9, 2006 09:40 AM
