Auto Start/Stop Function tip
1) Pres the break pedal 2) Push Start to start your car 3) Press your Start/Stop, to disable your start/stop for the remainder of your drive
that is, if you care about your engine
The happiest moment of my life was the day I installed an automatic turn off device for this. Well, perhaps I exaggerate a bit, LOL. There are many things on new cars that seem like a great idea on paper, but in execution they are the epitome of "Meh!". Like run flat tires, on paper great idea, in practice, not so much. The beautiful Lexus Infotainment screen another example. Beautiful screen with brand new interface, cloud based intelligence and OTA updates. In practice, well, it has its moments, good and bad. The start/stop saves a few drops of fuel and cuts down emissions, sounds good to me. Except in practice it requires beefed up starter motors to survive (not to mention the starter motors now have a pre-programmed death day where a CEL is set if you use the functionality a lot over the years), additional computer functions to track crankshaft/camshaft positions thru start/stop cycles to enable the fast startup, additional electronics/capacitors to prevent the rest of the vehicle's electronics from getting whacked by the sudden draw from the starter motor. Just a bunch of extra things happening to get this all to work and then it just puts more stress on the engine, the starter, and especially the battery. As the battery ages and wears from constant use it rapidly becomes less effective.
A minority of people like and are perfectly happy with all these paper-great, execution-questionable features, that's fine. I was one of them at one point. First car I had with start/stop (outside my hybrids of course) was a 2020 Crosstrek. I thought it was amazing and cool. 6 months later I installed an automatic start/stop OFF switch. When wife got a Forester, doing this was job one. AS/S on Subaru's is particularly rough. So here comes the NX, wow, its so smooth starting compared with the Subaru system, maybe I'll keep this on. Nope, by 9 months later I was sick of it too, in goes the automatic OFF device, LOL.
Hard on the starter, battery and your nerves.
I always turn it off.
I believe the computer is programed to keep count of the number of times the car goes into the start / stop mode and after a certain number of cycles the computer wants you to replace these components because the computer now considers they are at the end of their life. In this mode the battery and starter is now considered a normal wear item just likes brakes.
And did Toyota use a conventional starter in the new 350? Or is this all just assumption?
While conventional, these starter motors do have a higher duty cycle rating than a non-start stop car, but they function exactly the same. It is interesting that Toyota felt it necessary to code in a pre-determined starter replacement requirement after so many starts. Although in practice that time period shouldn't be too dissimilar to the typical life of a non start-stop starter motor in other cars depending of course how often the auto start stop is actually used. You don't see that on the hybrid systems and is another example of the difference in capabilities between how a hybrid starts an engine vs a non-hybrid with start/stop. The other side of the coin is, a starter replacement for the NX350 is relatively simple and not excessively costly. An engine starter type issue on a hybrid would be 10X the cost as that means the transmission is toast (but less likely to happen).
