NX - 2nd Gen (2022-current)
Weird 12V Battery charging Policy
Old Jan 19, 2025 | 06:25 AM
  #46
lsft's Avatar
lsft
Originally Posted by ronnaldbar
The weather is around 19 deg Celsius.
I am in Cyprus.
When you car is idle it will charge for sure, but when you are driving ... does it charge? You should be driving more than idling I assume?
Old Jan 19, 2025 | 07:34 AM
  #47
ronnaldbar's Avatar
ronnaldbar
On idle, the car is charging the battery (the voltage is 14.3V).
When driving, the voltage on the battery is 12.5-12.7V (90% of the time).
Old Jan 19, 2025 | 11:58 AM
  #48
Castrum's Avatar
Castrum
Veteran: Canadian Forces
Default Battery Maintenance Charge While Driving
  • A 12-volt battery that's fully charged should read about 12.6 volts on a multimeter.
  • Typically a 12-volt lead-acid battery is charged at 14.2 volts during the bulk charging stage (i.e. when that battery has been partially discharged.) Once the battery reaches full charge the charger should go into a maintenance mode.
  • A 12-volt battery should be maintained at 12.6 volts to ensure it's fully charged and healthy.
The profile that you are showing appears to be correct/normal.
bigblack06
Hybrid Technology
Aug 24, 2025 11:59 AM
worker
Mar 22, 2025 02:26 AM
Earman
42
Oct 25, 2024 07:53 PM
MX73
Mar 7, 2022 10:17 AM
diamondmit
Apr 2, 2009 02:17 PM
