NX - 2nd Gen (2022-current)
NX450h+ Connector Lock Setting
Old May 26, 2024 | 08:48 AM
jmreim11's Avatar
jmreim11
5th Gear
Default NX450h+ Connector Lock Setting
On my 2024 NX450h+, I'm trying to set it so that when the vehicle is fully charged, the locked charge connector will unlock. Unfortunately, the Connector Lock setting (in the Charging section) is grayed out. Assume that means some other setting is preventing it from being adjusted? Can someone point me in the right direction pls?
Old May 27, 2024 | 06:07 AM
lsft's Avatar
lsft
Whereabouts are you? Mine is not grayed out. Did you check when the plug is not plugged in or when it's plugged in?
Old May 27, 2024 | 06:35 AM
jmreim11's Avatar
jmreim11
5th Gear
I’m in the US. Thx very much for the help. Turns out I was plugged in when the item was grayed out. Once unplugged, I was able to make a selection. Again, many thx.
nicholair
Mar 15, 2024 02:57 PM
athanato
Oct 30, 2021 06:28 PM
NXOwner
NX - 1st Gen (2015-2021)
Oct 12, 2015 12:15 PM
Booyah
GX - 1st Gen (2003-2009)
Sep 16, 2011 01:13 PM
